2003 toyota sienna transponder bypass
start25
Copper - Posts: 114
Posted: March 17, 2006 at 4:12 PM / IP Logged
I found a topic in wich somebody described on how to bypass transponder with a relay but its not so detailed.  Here it is:
And yes you need the 555U. Actually it would be easier if you would just wrap some thin stranded wire around the key, Put it through a relay (87a and 30) and then 5 or 6 times around the key cylinder. Connect the relay coil to turn on with ground when running on the remote starter. Works every time especially on Siennas and you save a couple of bucks."
Can somebody explain how to do this more detailed, like wich wire goes to 85, 86, 87 connectors?
Thank you....
05gt
Silver - Posts: 628
Posted: March 17, 2006 at 4:22 PM / IP Logged
start at pin 30 on the relay, run a bare wire to the spare key wrap around several times continue this bare wire to the ignition cylinder wrap around several times, continue back to pin 87 on the relay, pin 86 goes to a igntion and pin 85 goes to the ground out when running wire from the remote start, or (-)status wire
start25
Copper - Posts: 114
Posted: March 17, 2006 at 4:52 PM / IP Logged
Thanks for your help, when you said "pin 86 goes to a igntion" do you mean to ignition wire or just wrap around ignition again?
Hornshockey
Silver - Posts: 520
Posted: March 17, 2006 at 5:11 PM / IP Logged
connect it to a switched ignition 12V source
Life moves pretty fast; if you don't stop and look around once in a while; you could miss it.
