98 mitsu eclipse
Edtfun
Member - Posts: 6
Posted: May 13, 2002 at 2:13 PM / IP Logged
I am trying to install a remote starter into my eclipse.
I need help bad, i have no wiring diagrams and the instruction that they provide are not very good at all. i need informatoin on how to proform this install.
edtfun
wirewise
Moderator - Posts: 489
Posted: May 13, 2002 at 2:22 PM / IP Logged
Hey EDTFUN, what specific information or parts of the install do you need help with?
For the wiring info for your vehicle look here: https://www.the12volt.com/installbay/detail.asp?info=alarm&year=1998&make=Mitsubishi&model=Eclipse&ID=18460&type=Alarm
~wirewise~
Big Dog
Gold - Posts: 1,265
Posted: May 13, 2002 at 2:55 PM / IP Logged
Hey EDTFUN,
What brand and model is your starter?  Is your Mtsu a manual?
Prepare your future. It wasn't the lack of stones that killed the stone age.
Edtfun
Member - Posts: 6
Posted: May 14, 2002 at 11:50 AM / IP Logged
IT IS AN ULTRASTARTER 1250M. I AM JUST LOOKING FOR THE TACH WIRE NOW. I STARTED WORKING ON THE INSTALL LAST NIGHT, BUT WAS UNABLE TO FINISH. YES MY MITSU IS A MANUAL.
 P.S. PLEASE DON'T MIND THE CAPS.
edtfun
Edtfun
Member - Posts: 6
Posted: May 15, 2002 at 7:05 AM / IP Logged
Can I find a tach signal inside the car, because I can't find a hole in the fire wall to run a line to the engine compartment. Other than that I think that every thing else is O.K. I also need to know weather or not i need to use the hood pin.
edtfun
Platinum - Posts: 12,488
Posted: May 15, 2002 at 8:36 PM / IP Logged
Tach  Signal:
WHITE OR BLUE/RED
PIN 8 AT ENGINE CONTROL MODULE *
Parking Lights:
GREEN / WHITE
(+) FUSE/JUNCTION BLOCK OR DIMMER
Headlights:
RED
(-) AT HEADLIGHT SWITCH OR RELAY
OEM Alarm  Disarm:
GREEN / WHITE
(-) DRIVER KICK PANEL
OEM Alarm  Arm:
GREEN/ YELLOW
Notes:
 * Engine Control Module (ECM) Located On Driver Wheelwell. WHITE Tach Wire Is Also Located At Pin #6 In A White 18 Pin Connector Behind Driver Side Of Console.
try this and see if this will help you out.
Edtfun
Member - Posts: 6
Posted: May 18, 2002 at 7:29 AM / IP Logged
O.K. evey thing is on and working, there is one problem. The remote starter will not start unless
I hold the clutch in. The installation guide says that as long as the remote starter is set for reservation mode, that it should start. By pushing in the brakes, and pulling the parking brake, when I turn the key off, and take it out the car still is running. When I exit the car, and close the door the car shuts off, and is in reservation mode. According to this installation guide, this process is the temporary clutch bypass.
I need to know how to get the car to remote start with out me in the car. 98 mitsu eclipse -- posted image.
edtfun
the12volt
Administrator - Posts: 3,959
Posted: May 18, 2002 at 7:42 AM / IP Logged
Hi Edtfun, first thing that comes to mind...did you wire it to bypass the clutch? I realize it has the capability to bypass the clutch, but if you didn't wire it, you'll need to add a relay to close the two leads on the clutch switch during remote start.
the12volt
Edtfun
Member - Posts: 6
Posted: May 18, 2002 at 1:42 PM / IP Logged
Thanks for the advice the12volt, but how do i go about wiring the relay.
edtfun
Edtfun
Member - Posts: 6
Posted: May 20, 2002 at 8:42 AM / IP Logged
Where can i find the clutch switch.
please help.
edtfun
Monday, March 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
