1994 Mercury Villager, new CD, no dash lights
bscott1238
Posted: March 22, 2006 at 7:51 PM / IP Logged
Hello! I'm hoping someone can help with this. My wife has a 1994 Mercury Villager, and I just installed a new CD player in it yesterday. The CD player works great, but now none of her dash lights are working at night (when she turns her lights on). I'm donkeyuming this has something to do with a few extra wires that were plugged into the back of the old radio that I left had to leave unplugged when I installed the new radio (because there was nowhere to plug these into the new radio using a wiring harness, of course). The problem is that I can't seem to find a wiring diagram anywhere that helps with this or anything in any forum online. Anybody ever run into this? Can somebody tell me what to do to correct this?
Thanks in advance!
bscott1238
Posted: March 22, 2006 at 7:53 PM / IP Logged
That "donkeyumming" above is the word ***uming... guess it didn't like the a double-s and replaced it!
xscash
Copper - Posts: 317
Posted: March 22, 2006 at 8:25 PM / IP Logged
sounds like you either left the interior ill. wire bare and it contacted the case of the radio...or you tapped it for a ground.  this ground is common when people install during the day,the wire will show ground until the lights are turned on and then it goes positive and blows a fuse.  either way... it should be a fuse. but you should check the wiring before replacing with a good fuse.
XS
bscott1238
Posted: March 23, 2006 at 6:22 PM / IP Logged
Thanks for the response, but that's not the case. I didn't have to tap any wires for a ground, as that was built into the wiring harness that I used. I didn't leave any wires bare - there were two small factory harnesses that plugged into the back of the factory radio (in addition to the two main harnesses for power and speakers), so I had to leave those two factory harnesses unplugged (since there was nowhere to plug them with the new aftermarket radio). I checked the fuse which controls the illumination panel and chime, and the fuse isn't blown. Anybody else have any suggestions?
geepherder
Platinum - Posts: 3,668
Posted: March 24, 2006 at 12:53 PM / IP Logged
I know it sounds stupid, but check the position of the dimmer switch.  (It annoys me when other people drive a company car and have to tweak with basically everything.)  Other than that, disconnect the dimmer/illumination wires from the stereo harness to eliminate them as possible culprits.  I'd probably next reinstall the factory deck to ensure they still come on with it.  You can always check the bulbs if not.  If they do come on, meter the wires behind the cluster and see what wire(s) read(s) differently with the factory deck or the aftermarket deck installed.  From there, you can post your results if you're unable to come up with a solution and I'm sure someone will gladly help you.
