Sub Wiring Confusion
randon
Posted: March 23, 2006 at 8:47 AM / IP Logged
Hi i recently bought 2 kickerCVR 12" (dual 4ohm). i know i am going to wire them by series-parralel to make a 4ohm load. i have a mono amp. but what i dont understand is, when i wire the (+) to the (-) on each sub, do i use the positive side of the speaker wire or the negative side or BOTH. and one more thing. do i use 1 wire to connect the 2 subs together or do i just leave the subs separate and have 2 wire going in each terminal in the amp. i looked at the wiring diagram but im still a lil confused. thanks
Platinum - Posts: 12,488
Posted: March 23, 2006 at 9:00 AM / IP Logged
This is what it should look like with the wiring: ( lines represent a single speaker wire )
Sub Wiring Confusion -- posted image.
randon
Posted: March 23, 2006 at 9:06 AM / IP Logged
ok well that answers one question. thnx.
so for my last question, when i connect the (+) to the (-) do i use the positve side of the speaker wire or the negative or both?
stevdart
Platinum - Posts: 5,816
Posted: March 23, 2006 at 9:11 AM / IP Logged
You have to take a piece of each of the + and - wires and splice them together in the middle so you end up with one end + and the other end -.
Just kidding.  A wire is neither positive nor negative.  It is just a conduit for current.  Use a single strand of wire to connect those terminals.
randon
Posted: March 23, 2006 at 9:17 AM / IP Logged
man THANK YOU big time, ive been trying to figure this out for like a week and none of my buddies can answer me. now one final question. i bought an alpine mrd-m1005, why i dont know. i shouldve got the mb quart amp i saw. anyways, the alpine isnt gonna give me enough power so what do you think would happen if i wired it for a 1ohm load.
stevdart
Posted: March 23, 2006 at 9:20 AM / IP Logged
Does the amp specs show a power output into 1 ohm?  If not, don't do it.
Posted: March 23, 2006 at 9:23 AM / IP Logged
All Alpine mono amps can not support a 1 ohm load. Minimum is a 2 ohm load. You can not get a 2 ohm load with 2 Dual 4 ohm subs. You have to trade them in for 2 dual 2 ohms subs to get a 2 ohm load.
randon
Posted: March 23, 2006 at 9:26 AM / IP Logged
yea thats definately where i went wrong. i shouldve got the dual 2ohm subs. but i got a screamin deal on the ones i bought 70$ a peice brand new. well thanks a lot everyone. it helped a lot.
djlayz
Copper - Posts: 104
Posted: March 23, 2006 at 12:24 PM / IP Logged
do what i did i just bought another amp. i got 2 dvc type r's goin to 2 mrd-m501 (1 sub per amp) and its really really loud.
