Bad batch of resin/hardner from SP?
meltingplastic
Copper - Posts: 225
Posted: March 25, 2006 at 8:34 PM / IP Logged
Hey guys,
so i'm undertaking a fiberglassing project for my S10 and ordered everything from Select Products. Everythings going great except for the resin and hardener. I've been using like double the amount of hadrener they have on the bottle for my batches and the thing takes FOREVER to cure. I mean it doesnt cure for OVER 24 hours. I mean i understand it takes a while for it all to cure but i'm mixing hot batches and they just dont seem to want to. I dont want to boil a batch so i've limitted it at 2 times the amount they recommend but i'm just confused as to why its taking so long to cure... ne suggestions as to what amount of hardener i should use per measurement of resin?
Driving a Bagged, Caddied 02 s10
auex
Platinum - Posts: 5,041
Posted: March 25, 2006 at 8:38 PM / IP Logged
What is the temp like where you are?
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
meltingplastic
Copper - Posts: 225
Posted: March 25, 2006 at 8:49 PM / IP Logged
around 50 to 60 degrees. if the doors are closed 65
toolinmaine
Member - Posts: 26
Posted: March 26, 2006 at 10:32 AM / IP Logged
Directsunlight or Heat Lamps. Magical
eric anderson-nosredna cire
Moderator - Posts: 12,488
Posted: March 26, 2006 at 12:13 PM / IP Logged
I'd say it's a bad batch. I had the same problem once and I returned it for a new batch of resin and it worked instantly and you can tell it was working because when mixed, the resin would turn brown with the hardener.
meltingplastic
Copper - Posts: 225
Posted: March 26, 2006 at 4:33 PM / IP Logged
yea its not changing colors really when i add the hardener
Aruman
Silver - Posts: 363
Posted: March 27, 2006 at 9:36 AM / IP Logged
did you heat the resin making it warm before ? have you seen the dvd of them?
xclusivecustoms
Member - Posts: 24
Posted: March 27, 2006 at 5:10 PM / IP Logged
You need to warm your shop to over 75 degrees to use fiberglass. If not, it could take a month for it to harden. Adding more than 2% MEKP to polyester resin is just asking for problems.
Aruman
Silver - Posts: 363
Posted: March 27, 2006 at 8:48 PM / IP Logged
yep no more then 2% of MEKP for 500mL of resin
Posted: March 27, 2006 at 9:42 PM / IP Logged
I've fiberglassed at 60 deg F before without a problem. Just have to make sure that you give it a bit more time and that the project doesn't warp on you if you decide to bring the temp above 70 deg F.
