2003 tahoe w/bose aftermarket amp
djsnake210
Member - Posts: 6
Posted: March 26, 2006 at 12:07 AM / IP Logged
I'm trying to install an aftermarket amp in an '03 tahoe with bose and i'm having issues with the wiring. I thought with it being the bose system i needed the PAC C2A-GM24 adapter since the listings for it highlighted the fact that it was for bose systems (although Data-II digital bus). I got no sound. I figure that didn't work since I probably need the regular AOEM adapter. but since i had it apart I figured i would use a high-to-low level converter instead and splice into the wiring directly after the head unit using the wiring diagram i found on this site. this produced the same result. i get nothing. are the wires coming out of the headunit already low level? is there something else i should be checking or a different way i should be hooking this up? i would just hate to buy the other PAC adapter (PAC AOEM-GM24) and still get nothing to find out i needed to do something else. thanks for any help i can get. i've been working on troubleshooting this for about 7 hrs straight.
Jake
sick ca yukon
Member - Posts: 18
Posted: March 26, 2006 at 12:30 PM / IP Logged
I have a 2006 Yukon I am working on, I have the stock radio with the disk changer and with out navigation.  I do have the Bose system, I was able to add a hi/low converter to my system.  I tapped into it right underneath the cup holders in the center console.  That is is where the amp is and you have to tap into the right wires after the amp source.  I have heard that if you want to test the wires, you can tap a 9volt battery to the wires and the speaker should pop. Just to know for sure before your done that you have speaker wires.
djsnake210
Member - Posts: 6
Posted: March 26, 2006 at 2:48 PM / IP Logged
Thanks for the help. I got in under the console and see the wiring, but there are two harnesses side by side. which one is out to speakers? one has a blue tab, the other is gray.  also are the wires still color coordinated (right rear+ blue, right rear- lt blue, left rear+ brown, left rear- yellow)? Thanks again.
Jake
djsnake210
Member - Posts: 6
Posted: March 26, 2006 at 2:50 PM / IP Logged
oh yeah.... sorry... i forgot to mention this is without navigation.
Jake
sick ca yukon
Member - Posts: 18
Posted: March 26, 2006 at 2:53 PM / IP Logged
Sounds like the same setup I have, I spliced into those same wires and hooked in my hi/low converter w/ solder.  I tapped in right under the cup holder's there is a lot more room to work with.  I used the amp for wiring in subs.  I think there might be more involved if you want to use it for high/low speakers...
djsnake210
Member - Posts: 6
Posted: March 26, 2006 at 2:59 PM / IP Logged
Actually I'm just using this to add an aftermarket amp and two subs. i'm just wondering the color of the wires i need to splice off of, as well as which harness is going out. all i see is two harnesses side by side. or is there a third harness on the other side of the amp (toward the front of the vehicle) since i can't see that end of the amp.
Jake
sick ca yukon
Member - Posts: 18
Posted: March 26, 2006 at 3:21 PM / IP Logged
Can you take out the cupholder portion of the console?
You are wiring in the same setup I have.  I am using an aftermarket amp to power to 12's.  Everything else is stock...
djsnake210
Member - Posts: 6
Posted: March 26, 2006 at 3:34 PM / IP Logged
yeah i got the cupholder portion out... i see a big wiring harness that has two of each wire color (ex. two lt blues, two blues, two tans, etc). would it be easier to just cut into the wire right before it connects to the speakers in the back panel?
Jake
djsnake210
Member - Posts: 6
Posted: March 26, 2006 at 5:52 PM / IP Logged
Well it all worked out... i found the wires after the amp and got them all hooked up and it sounds great! Thanks again for your help.
Jake
sick ca yukon
Member - Posts: 18
Posted: March 26, 2006 at 11:46 PM / IP Logged
My interior lights dim a little when the gain is up and the bass hits.  I think my setup is pretty small, only 1 amp 200 watt rms with 2 fosgate p1 12's.   What did you go with for your subs and amp?
