Upgrade of keyless Entry
namracj
Member - Posts: 12
Posted: May 13, 2002 at 7:55 PM / IP Logged
I'm having no luck installing alarm to work through my keyless system.Alarm is a Guardian model 911-800. Vehicle is a 2002 Subaru Forester. Problem tieing alarm into keyless entry module.Looking for Doorlock power switch & actuator circuits.Wiring diagram vehicle says find (-) pulse wires to trigger unit. Thought I found the correct wires, but unit still arms/disarms with both remote & door switches. I'm working at the harness leading to the drivers door. Do I have to go into the door panel to find correct wires? Can really use so help. Thanks. John.
john
Platinum - Posts: 12,488
Posted: May 13, 2002 at 8:27 PM / IP Logged
Hey John, sounds like your pretty frustrated witht his install already. In the diagram that I sent you, it said that the wires are at the key ( inside the door ) You will most likely have to take the door panel off and wire it straight to the switch ( if you haven't already done so ). Test all the target wires in the switch on the door and apply a ground wire to the target unlock/lock wire to see if this will activate the locking mechanism. Post your results.
namracj
Member - Posts: 12
Posted: May 13, 2002 at 8:51 PM / IP Logged
Jeff; Your right I'm stumped. At the Remote keyless entry module I found a wire that locks doors when grounded, and one that unlocks doors when grounded. The same wires lead to the door harness. I tried using these in addition to (+) lock, (+) unlock, & (+) unlock other door wires but still no success. The different wiring connections in the alarm instructions aren't very clear, at least to me. I will try to open the door panel and check for more wires. Any other ideas. Thanks for your help. John.
john
veedub
Posted: May 13, 2002 at 9:11 PM / IP Logged
    you might have the wires from the lock motor.....that might be the reason why you can activate the alarm from the door switch
namracj
Member - Posts: 12
Posted: May 13, 2002 at 9:18 PM / IP Logged
Thanks for the imput. I know i've got something hooked up wrong. I guess I'll go into the door panel after the correct wires. I figured I could find them all at the harness and make things easy. John.
john
