2005 Mercedes C230 Security wiring
jmzuvich
Posted: April 03, 2006 at 11:45 PM / IP Logged
I need to install a security system into a Mercedes c230.  I can't find any wiing diagrams.
Any kind of information would be very helpful.
xscash
Copper - Posts: 317
Posted: April 14, 2006 at 8:30 PM / IP Logged
here you go, good luck.
xs
2005 MERCEDES C230 2DR HATCHBACK KOMPRESSOR®
 Audio/Mobile Video
 WIRE  COLOR  POLARITY  LOCATION
 Battery  PINK/GREEN  (+)  RADIO HARNESS
 Accesory  RED / BLUE  (+)  RADIO HARNESS
 Ground  BROWN  (-)  RADIO HARNESS
 Dimmer  GRAY/BLUE  (+)  RADIO HARNESS
 Power Antenna  BLUE/WHITE  (+)  RADIO HARNESS
 LF Speaker (+)  GREEN
 LF Speaker (-)  BROWN / GREEN
 RF Speaker (+)  ORANGE
 RF Speaker (-)  BROWN / ORANGE
 LR Speaker (+)  PINK
 LR Speaker (-)  BROWN / PINK
 RR Speaker (+)  WHITE
 RR Speaker (-)  BROWN / WHITE
 Radio Security  YES
 Security
 Battery  RED  (+)  IGNITION SWITCH HARNESS
 Ignition 1  PINK/RED  (+)  IGNITION SWITCH HARNESS
 Starter 1  VIOLET  (+)  IGNITION SWITCH HARNESS
 LF Latch  BROWN / GRAY  (-)  IN PASSENGER DOOR SILL HARNESS
 RF Latch  BROWN / BLUE  (-)  IN PASSENGER DOOR SILL HARNESS
 Trunk Trigger  BROWN / WHITE  (-)  IN HARNESS FROM TRUNK
 Parking Lights  GRAY/WHITE  (+)  AT VEHICLE LIGHT SWITCH
 Convenience
 Headlights-Lo  WHITE/ YELLOW  (+)  AT VEHICLE LIGHT SWITCH
 Trnk Release  VIOLET  (-)  AT TRUNK RELEASE SWITCH
 Remote Start
 Ignition 2  PINK/BLUE  (+)  IGNITION SWITCH HARNESS
 Accessory 1  PINK/GREEN  (+)  IGNITION SWITCH HARNESS
 Anti-Theft Type  UNIVERSAL IMMOBILIZER
 Anti-Theft Descript  THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
 Key Sense  PINK/BLUE  (-)  IGNITION SWITCH HARNESS
 Tachometer  GREEN/ YELLOW  (-)  AT MODULE ON PASSENGER SIDE BACK OF ENGINE
 Speed Sense  GREEN / WHITE  (AC)  RADIO HARNESS
 Brake Lights  BLACK/ RED  (+)  AT SWITCH ABOVE BRAKE PEDAL
 Reverse Lights  GREEN/ YELLOW  (+)  IN HARNESS TO TRANSMISSION
 Modules
 WIRE  LOCATION
 Please select another category
 Doorlocks/Windows
 Power Unlock  BLUE  (-)  IN HARNESS IN DRIVERS KICKPANEL
 PowerLock  BLACK  (-)  IN HARNESS IN DRIVERS KICKPANEL
expandable sound
south of boston
