Headunit outputs full range to all speaks
coppellstereo
Silver - Posts: 785
Posted: April 04, 2006 at 8:00 PM / IP Logged
We installed a subwoofer in my girlfriend's car, and her headunit only had one RCA output - REAR. So the HU is sending the full range signal to all of the speakers. Sub is crossed over at the amp. Until we upgrade her HU or get a new set of speakers all the way around, would bass blockers solve our problem? Do they allow any midrange through? How do they install?
Thanks!
sparkie
Platinum - Posts: 2,061
Posted: April 04, 2006 at 8:29 PM / IP Logged
You didn't state your probelm. I will assume that your other speakers are distorting from too much bass. Depending on your car and your existing speakers, they may not be great at handling bass of any amount. Bass blockers are simply capacitors that filter out certain sound frequencies. They filter out freq. at 6dB/octave. Different values in caps. will change at which freq. the caps. begin to filter out sound. Yes, they will allow midrange through, as they are primarily designed to start at freq. well below midrange. You need non-polarized caps. They install inline on the positive speaker line to each speaker. The downside to these is that they put the speaker out of phase by 90 degrees. Some vehicles have other solutions so post your vehicle type and system lay out so others can offer suggestions.
sparky
coppellstereo
Silver - Posts: 785
Posted: April 04, 2006 at 8:32 PM / IP Logged
Yeah, that is the problem.
She has a 2001 Honda Civic EX.
She is using a sony HU with stock speakers (not component, nor coax - just standard).
stevdart
Platinum - Posts: 5,816
Posted: April 04, 2006 at 8:51 PM / IP Logged
Get her a $99 amp and a pair of $49 coaxials.  Will take care of the crossover problem and provide better highs to compliment the new sub install.  (...prices shown are valid only if you are a careful and frugal shopper of discontinued products...;)
coppellstereo
Silver - Posts: 785
Posted: April 04, 2006 at 9:29 PM / IP Logged
Well, that is my eventual plan! Was just looking for a quick fix for now.
coppellstereo
Silver - Posts: 785
Posted: April 04, 2006 at 11:03 PM / IP Logged
What is a good crossover value for these bass blockers?
What does being out of phase of 90 degrees actually mean?
stevdart
Posted: April 04, 2006 at 11:46 PM / IP Logged
http://www.mhsoft.nl/spk_calc.asp#crossover
http://www.partsexpress.com/pe/pshowdetl.cfm?&DID=7&Partnumber=027-370  cheap but effective.
A 250 uF cap on a 4 ohm woofer will start the 6 db / octave slope at about 160 Hz.  But keep in mind that it is 6 db per octave, so the woofer output is attenuated by 6 decibels at 80 Hz.
https://www.the12volt.com/caraudio/cross.asp#hp shows the hookup.
Headunit outputs full range to all speaks -- posted image.
90 degrees out of phase is an "in-between" problem that can't be fixed by reversing polarity on one of the drivers, as an 180 degree out of  phase situation would be.  The cure is to reposition one of the drivers if this out-of-phase issue is a problem.  It would manifest itself as a "muddying" of the sound.
coppellstereo
Silver - Posts: 785
Posted: April 05, 2006 at 12:10 AM / IP Logged
This is what it would look like if 2 woofers were both out of phase by 90 degrees?
i found this animation.
http://www.sfu.ca/sca/Manuals/ZAAPf/p/phase.html
I'm not quite grasping why adding these capacitors puts the speakers out of phase. Is it because it induces lag? Wouldnt both speakers be lagging by the same amount?
stevdart
Posted: April 05, 2006 at 7:48 AM / IP Logged
Phase shift induced by the various orders of crossovers is something I can't explain, because I don't understand it myself very well.  But, suffice to say, if both L and R speakers have the same crossover, they will be identical with no phase shift between one and the other.  Read  2.1 Phase shift vs. time delay in Rod Elliott's site.
The importance of this phase shift phenomemon becomes apparent when designing a two-way or three-way crossover network.  A design program like Speaker Workshop helps me to get the phase rignt in the network even though I"m not sure how...Headunit outputs full range to all speaks -- posted image.  But anyway, as I understand it, the importance is the phase difference between two or more drivers in the same network (like a component set or simple coaxial)...not the difference between the front pair and rear pair of speakers in an installed system.
Okay, here's an illustration:  say you have a simple pair of coaxials with the 1st order crossover (capacitor) already built in, which helps to block low freqs from the tweeter.  The drivers in that network (the mid and tweeter) are designed to work together with the knowledge that there is a 1st order, 90 degree phase shift, crossover included.  The coaxial will sound just fine if you leave it alone, for what it's worth.  Now, say you want to mess with it...you pull out the cap and replace it with a textbook 2rd order crossover, consisting of a cap and a coil.  The phase difference is 90 degrees per order, so now you have a 180 degree phase shift between the tweeter and the mid, but you haven't made any other changes to the network to compensate for that difference.  The result would probably be less desirable than if you just left it alone to begin with.
(...somebody correct me if I'm whacked out on this one...)
coppellstereo
Silver - Posts: 785
Posted: April 05, 2006 at 3:08 PM / IP Logged
There isnt a tweeter on these speakers, just mid-range speakers all the way around.
I dont think that there would be a phase shift if all of these speakers had the same capacitor, do you?
Also, where is a good cutoff freq for these mid-range speakers?
HPF @ 150-200 Hz?
