97 Toyota T100, cruise control
Texastintchick
Member - Posts: 7
Posted: April 05, 2006 at 10:20 AM / IP Logged
I am installing a CC in this vehicle.  Can someone help me find the speed sensor wire.  I have located the ECU in the passenger kick, however, I am not able to locate the right wire.
TIA
ttc
xscash
Copper - Posts: 317
Posted: April 05, 2006 at 1:38 PM / IP Logged
here you go,
Speed Sense GREEN (AC) PASS.SIDE KICK 22 PIN PLUG POS 8OR9 ECM
XS
expandable sound
south of boston
Texastintchick
Member - Posts: 7
Posted: April 05, 2006 at 3:06 PM / IP Logged
It did not work the truck would not go over about 2MPH with it plugged in!  Thanks so much for trying to help.
Could it be a green w/ a tracer?
ttc
mo12v
Posted: April 07, 2006 at 9:38 PM / IP Logged
Try:
Position 8 or 9 of 22 Pin Conn at ECM or Position 12 of 28 Pin Con
VSS Wire Color: Green
MO
doibuy
Copper - Posts: 177
Posted: April 07, 2006 at 11:44 PM / IP Logged
Toyota sometimes uses GREEN/ orange
