99 Alero - Poor FM Reception
mv577
Member - Posts: 18
Posted: January 03, 2003 at 9:34 AM / IP Logged
Hello all...
I'm working on a 99 Alero with really poor FM reception... As you probably know the antenna is in the back window....
If this needed to be replaced... how would I go about it???
A little note on the car... it's a stock system.... so any other thoughts on the poor reception are very welcome...
Thanks In Advance!
Mike
securinu
Silver - Posts: 772
Posted: January 03, 2003 at 10:51 AM / IP Logged
just go get a cheap fender mount antenna and tie strap it under the rear deck , cant be any worse than a window antenna. i did this on an accord coupe i had and it was better than the window antenna. just be sure to ground the base to the car . we do this in boats too and it works great.
rangersvtsplash
Posted: January 03, 2003 at 12:27 PM / IP Logged
ive got a alpine cda-7878 in a ford ranger and it too has static fm what can i do? is it the radio or the antenna? ive had days its good on the same channel but days that fuzzy. email me luismateus@rogers.com ive been  told than fm amplifiers are not good and can damage the hu?
luis
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
