Blaupunkt Monte Carlo MP34 wiring
natedogg625
Posted: April 11, 2006 at 8:39 PM / IP Logged
I have a Montey Carlo MP34, and I have a few wires that I dont know what to do w/...
The first is the Tele-mute wire, its green...what does this do?? and where does it get wired to?
The second is a blue Antenna wire...on the back of the HU there is a spot for a plug in antenna.
and the red ignition wire is for when you turn the key to accessory, and the radio turns on right?
and the car its getting wired into is a 1995 Chevy Cavalier
Thanx in advance
godblessdremil
Silver - Posts: 273
Posted: April 12, 2006 at 9:18 AM / IP Logged
1) tele-mute is if you have a handsfree kit, it mutes the radio durring the phone call. Tape that off
2) the blue antenna wire is for the raising of the power antenna. If you don't have a power antenna just tape it off
3) red is the turn on yess, yellow is memory and must be connected to a constant 12 volt source
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
