fg gauge pod
hakosuka
Member - Posts: 37
Posted: April 13, 2006 at 7:56 AM / IP Logged
just made thisin about 2 days, glassed it from the inside so there would be less sanding.  it goes into the cd player slot in a skyline.  is there any thing i should have done or any thing i coulda done better? any input is appreciated.
fg gauge pod -- posted image.
hakosuka
Member - Posts: 37
Posted: April 13, 2006 at 8:11 AM / IP Logged
o ya, i plan on painting it again, cuz i messed up the first time
Platinum - Posts: 12,488
Posted: April 13, 2006 at 8:37 AM / IP Logged
Do you have any power tools that could have helped you cut the straight parts ? Even using a dremel with a straight edge adaptor would have helped cause this would give the project a more professional look to it. Also, instead of making your own trim ring you could have used a PVC pipe instead that was the same inner diameter and this would give you a perfect circle. Otherwise you did you a good job if you didn't have the proper tools.
hakosuka
Member - Posts: 37
Posted: April 13, 2006 at 9:24 AM / IP Logged
all the tools i had to make this were a jigsaw, dremel, and a drill, but i didnt have the straight edge adapter for the dremel. im pretty new to fiberglassing and made this for my friend, and only the front will show, so i wasnt too concerned with the back.  thanks for the feedback on this topic and for the box cover velocity.
hakosuka
Member - Posts: 37
Posted: April 14, 2006 at 6:30 AM / IP Logged
heres some updated pics
hakosuka
Member - Posts: 37
Posted: April 15, 2006 at 8:33 AM / IP Logged
i think next time i do a pod i will use pvc, because i had trouble getting the gauge to fit, but it eventually did after a while of shaving it down
Posted: April 15, 2006 at 8:44 AM / IP Logged
Looks great but I would have kept the OEM colors of the GT badge myself fg gauge pod -- posted image.
