Basic alarm, ’04 Pontiac Sunfire
jbishop
Posted: April 13, 2006 at 9:07 PM / IP Logged
Getting ready to do an install a Viper 350 on a 2004 Pontiac Sunfire, anyone got the "Directwire" for it?
swamprat323
Gold - Posts: 1,335
Posted: April 13, 2006 at 10:01 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - PONTIAC / SUNFIRE / 2004 / Remote Start
[PRINT THIS PAGE]
12volts red (x2)(common 50A)   +   ignition harness
Starter yellow   +   ignition harness
Second Starter N/A
Ignition pink   +   ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory orange   +   ignition harness
Second Accessory brown   +   ignition harness
Keysense lt. green   -   ign harn or BCM, brown plug, pin B12
Notes: The BCM is above the driver kick panel.
Power Lock lt. blue   +   BCM, purple plug, pin A4
On vehicles without keyless entry, the door lock wires are just located in either kick panel. They are 5wi (Type C), and mastered from the passenger door lock switch.
Power Unlock white   +   BCM, purple plug, pin A3
Lock Motor gray   5wi driver kick or door lock relay
Notes: The door lock relay is above the passenger kick panel.
Unlock Motor tan   5wi BCM, purple plug, pin A6
Parking Lights+ brown   +   BCM, blue plug, pin A1
Parking Lights- N/A
Hazards same as turn signal wires
Turn Signal(L) lt. blue (F), yellow (R)   +   turn signal switch
Turn Signal(R) dk. blue (F), dk. green (R)   +   turn signal switch
Reverse Light lt. green   +   driver kick, harness to rear
Door Trigger lt. GREEN/ black and lt. blue   -   BCM, purple plug, pins A7 and A8
Notes: The driver door trigger is lt. GREEN/ black, and the passenger door(s) is lt. blue. Use both wires and diode isolate each.
Dome Supervision white   -   BCM, brown plug, pin A1
Trunk/Hatch Pin ORANGE / black   -   BCM, blue plug, pin A4
Hood Pin N/A
Trunk/Hatch Release BLACK/ white   -   BCM, blue plug, pin B4
Power Sliding Door N/A
Factory Alarm Arm factory remote only
Factory Alarm Disarm factory remote only
Disarm No Unlock with ignition and Passlock
Tachometer white or orange   ac   Ignition Control Module
Notes: The Ignition Control Module is on the driver side top of the engine.
Wait to start N/A
Brake Wire white   +   brake pedal switch
Parking Brake lt. blue   -   BCM, blue plug, pin B2
Horn Trigger black   -   BCM, brown plug, pin B7
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Passlock II
Part #: 556LW
Alternate Part1 #: 555LW
Alternate Part2 #: DesignTech 20402
Alternate Part3 #: DesignTech 29402
Notes: The Passlock II wire colors are yellow, black, and white (not used).
Door Lock Interface Required:
No Type:
N/A
Part #: N/A
Notes:
Combo Interface Required:
Yes Type:
Data Bus
Part #: 457GW
Notes: Can use the 457GW to bypass the Passlock II, but it will not control the door locks on this model year.
swamprat323
Gold - Posts: 1,335
Posted: April 13, 2006 at 10:10 PM / IP Logged
the under part of the driver side dash can not come off. i did nto liek doign this car.
jbishop
Posted: April 14, 2006 at 6:31 PM / IP Logged
Thanks, just got done, not too bad, the dash is crazy like a Chev Cavalier, all the wires are right there at the BCM and easy  to get to.
Ravendarat
Platinum - Posts: 2,806
Posted: April 15, 2006 at 12:04 PM / IP Logged
I love doing that car because most alarms can be done in about an hour with options and always work.
Tuesday, March 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
