video screens problem
xllsc
Member - Posts: 18
Posted: April 14, 2006 at 10:45 AM / IP Logged
i installed two new 5.6 performance teknique in the sunvisors yesterday. and new dvd same make
while playing  the dvd and video the screens jumped to no signal the went back to showing the movie, the went to no signal. the screens are wraped in suede ad top high line rca cables.check grounds and power cables. show i use the in line 2amp fuse whe using another tv from the dvd i works ok.
any help i would love.thanks  CEE
get your grind on
prodigal
Copper - Posts: 62
Posted: April 24, 2006 at 5:15 PM / IP Logged
i have similar problems with my dvd sreen too. It shows no signal for a second and then the image comes back normal. Wonder what causes this
Prodigal Son
doibuy
Copper - Posts: 177
Posted: April 24, 2006 at 5:23 PM / IP Logged
Not familiar with that brand, but you should try to add a video amplifier, that will boost the signal to the highest possible.  When you split the signal on some DVDs you loose some of the signal.  If this doesn't fix it, try other screens.  Not all screens out there are good quality.
