Problems with head unit
btighe
Posted: April 16, 2006 at 6:39 PM / IP Logged
I've been having problems with my head units the past few months, when its on all it plays, no matter what setting or input, is static.  There will be a little bit of music music, but its mostly just static.
I originally had a Pioneer in, which is where the problem started, but after redoing all the connections, checking all the fuses, and taking some electrical contact cleaner to the plugs it was still there.  I also have in pioneer speakers, all around, and I took all of them out, redid connections, swapped back in the stock speakers, and no matter what I did, nothing worked.  I then bought a new Alpine, and after redoing all the connections again, its still there.
At this point I'm thinking its the ground, but does anyone have any other ideas?
Thanks!
forbidden
Platinum - Posts: 5,352
Posted: April 16, 2006 at 7:53 PM / IP Logged
List the vehicle year, make ,model, does it have a hidden factory amplifier?
btighe
Posted: June 02, 2006 at 9:10 PM / IP Logged
1997 ford ranger...i was told there was a factory amp, but i havent found one.  if there is one, would that be worth checking out before the grounds?
geepherder
Platinum - Posts: 3,668
Posted: June 04, 2006 at 12:49 PM / IP Logged
Yes, it definitely sounds like a factory amp problem.  What you can do is pull your deck and run a small length of speaker wire directly from your deck to a test speaker.  Test all channels and if there's no noise, just run fresh wire directly from the deck to all speaker locations.
kgerry
Platinum - Posts: 3,455
Posted: June 06, 2006 at 3:33 PM / IP Logged
did you use any type of differential converter when hooking up your aftermarket HU?
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
btighe
Posted: June 09, 2006 at 8:31 AM / IP Logged
Thanks for the help, does anyone know where the factory amp might be?  If its somewhere easy to get to, I'm thinking it might be easier to connect the head unit wires right to the speaker wires there.  And no, I didn't use a diff. converter
djlayz
Copper - Posts: 104
Posted: June 09, 2006 at 12:31 PM / IP Logged
If there is a factory amp. To me it sounds like its not getting turned on, so that means there must be a remote wire for it that you need to connect to your HU.  Its probably a blue wire on the connector that goes to you factory HU.
btighe
Posted: June 09, 2006 at 1:10 PM / IP Logged
I got that wire, I've had it connected with both HUs and still no luck, unless somethings wrong with it on the amp or on the way
Sunday, April 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
