2006 VW Golf
dkeenan
Copper - Posts: 52
Posted: April 21, 2006 at 10:39 AM / IP Logged
Can anyone please tell me how to remove the stereo on this model of car and the connections for a nokia handsfree kit if possible.
Also, is it possible to get info on installing these kits to all models of cars.
Thanks,
Dwayne.
Ireland
jmscomm
Posted: April 24, 2006 at 5:11 PM / IP Logged
they can be hard to get apart but i will try to explain it to you
under the top panel of the dash there are 4 torx bit screws remove them and then the top section will come out but watch the vents as they are hard to get out as you have to pull them towards you and the clips are unforgiving
the secion around the deck will clip off and the deck is screwed in
the deck is can bus so there is constant and earth there and there is mute althought there is no wire in the plug so all you have to do is use the centre pin from an fme antenna plug and plug it into the pin that is shown on the diagram on top of the deck
accessories can be picked up at the acc socket below the deck
dkeenan
Copper - Posts: 52
Posted: May 02, 2006 at 1:06 PM / IP Logged
Gheers. Thanks very much
You can vote in polls in this forum
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
