clif designs cd10.1Lx is best at what
jayson358
Copper - Posts: 73
Posted: April 21, 2006 at 6:06 PM / IP Logged
ok guys my sub amp is a clif designs cd10.1Lx its a class a/b monoblock amp, 1 ohm mon stable, 0.02% T.H.D, s/n ratio >100db, channel seperation 65db, dampening factor 150, fuse 30 amp x 3 it has tiffany style rca jacks 1 in and 1 out, direct wire terminal blocks, xover switch full/lowpass, varible lpf is 40hz to 120hz, subsonik filter 10hz to 25hz, bass boost is 0db to 18db centered at 40hz, clif's claimed rating 1 x 350w rms @ 4 ohms, 1 x 500w rms @ 2 ohms, 1 x 700w rms @ 1 ohm, and 1000w max @ 1 ohms. now its cea compliant at 4 and 2 ohms. now there are 2 sets of speaker terminals on this amp but in the manual it says the amp is internally bridged so there is no need for outside bridging i know what that means but also the engineer @ clif told me i could run this amp @ 1/2 ohm on a single channel givin the right situation but i dont plan on it
so my question is what is ur thoughts on this brand, what would u rate this @ givin these specs i heard clif used to be really good bout 5 to 10 yrs ago but know one knows how they r now cause they jus went through allot of changes
and why is there a sub sonic adjust on there when the human ear can only hear to about 25-30hz and most subs can't produce anything lower (most not all) and its jus vibration to us any how well i appreciate any input ya'll have
93 diamante
pioneer deh-p3800mp
crossfire 40 band eq
alphasonik pma4075 mid amp
clif designs cd10.1Lx sub amp
powerbass xtreme 6 1/2 comp
"   " 6x9 rear
alpine 2 12" type r
ported 40hz tune
arrow12
Silver - Posts: 527
Posted: April 21, 2006 at 8:18 PM / IP Logged
The amp is one channel, right?  If it is, then why is there a channel separation?  The subsonic filter is used for mainly ported enclosures.  When a sub is in a ported enclosure their is only a certain frequency it can go down to.  As it hits that and goes lower, mechanical failures start to occur and your sub could go bye bye.  This is a lot harder to do in a sealed enclosure.
That's my opinion. Take it, leave it, or correct me.
jayson358
Copper - Posts: 73
Posted: April 21, 2006 at 8:38 PM / IP Logged
i dont know why it say it in the manual but it does and its a mono cannel amp plus they also told me thats why u dont bridge the 2 channels cause i had called and had asked for some info on the amp but whats ur opion on the stats of or any1 else
93 diamante
pioneer deh-p3800mp
"   " 6x9 rear
alpine 2 12" type r
ported 40hz tune
