2003 Grand Am Firewall gromet
brockotherock
Posted: April 24, 2006 at 12:14 PM / IP Logged
I am tring to find an existing gromet to pass a 4 gage amp wire throught the firewall of my 2003 Grand Am so I do not have to drill a new hole.  Any one have a diagram, explanaiton or better suggestion?
sparkie
Platinum - Posts: 2,061
Posted: April 24, 2006 at 2:33 PM / IP Logged
Under the driver's side dash you will see a large harness passing through the firewall near the kick panel. The grommet it goes through should have enough room in it for you to cut a small slit in it to pass the cable through. Use some putty to re-seal the gap around the hole to prevent water leaks.
sparky
