wiring codes needed for 1981 DeLorean DMC 12
Escalade_on20z
Member - Posts: 24
Posted: January 05, 2003 at 10:20 PM / IP Logged
Does anyone have alarm/remote start wiring codes for a 81 delorean.
Platinum - Posts: 12,488
Posted: January 05, 2003 at 10:32 PM / IP Logged
|              12V|BROWN / red           |+  |ign sw or relay panel       |
|          STARTER|WHITE/ red           |+  |ign sw or relay panel       |
|         IGNITION|white               |+  |ign sw or relay panel       |
|        ACCESSORY|WHITE/ green         |+  |ign sw or relay panel       |
|       POWER LOCK|RED / pink            |-  |door lock module *1         |
|     POWER UNLOCK|RED / gray            |-  |door lock module            |
| PARKING LIGHTS +|RED / orange          |   |light sw or dimmer          |
| PARKING LIGHTS -|                    |   |                            |
|       HEADLIGHTS|blue                |+  |light sw or st. column      |
|     DOOR TRIGGER|RED / blue *2         |-  |at gauges 'Door Ajar'       |
|       TACHOMETER|WHITE/ gray          |   |coil or ECU at engine       |
|       BRAKE WIRE|GREEN/ purple        |+  |brake pedal switch          |
|     HORN TRIGGER|PURPLE / black        |+  |at either horn              |
|           WIPERS|gray/lt. green      |+  |wiper switch                |
|  LF WINDOW UP/DN|gray/pur - gray/grn |A  |switch in console           |
|  RF WINDOW UP/DN|gray/red - gray/blu |A  |switch in console           |
Notes:
*1 Also located at relay panel located behind passenger seat. Battery located below relay panel.  *2 Also PURPLE / gray at driver's door or PURPLE / white at passenger door.
