2002 Pontiac Grand Am Tach Wire
craigsok
Posted: May 01, 2006 at 6:58 AM / IP Logged
Can someone help me determine which of the white wires on a 2002 Pontiac Grand Am is the tach wire on the module to the left side of the steering column? I am installing a remote start using the Bulldog RS1200E along with a bypass unit and the tach wire is used to reduce overcranking the engine. Bulldog's directions state that there are 4 white wires at this location connected to a grey colored tape harness and to try each one until it works. I don't feel comfortable doing this with ECM connections, so does anyone have a diagram that illustrates the terminal number or location within the terminal block?
Thank you,
Craigsok
Platinum - Posts: 12,488
Posted: May 01, 2006 at 11:21 AM / IP Logged
It's the PURPLE / WHITE wire at the driver's side harness and to my knowledge some models have ONLY one while others have 2. Test each one before connecting.
