remote start for bmw 320 e36
laff001
Posted: May 02, 2006 at 6:50 AM / IP Logged
Iam currently trying to install a remote start alarm from Spy, a two way car alarm. Iam stuck with the remote start not knowing were to put the wires on the car. Is there any diagrams or detailed information i could get anywere from the web or from any member here.
thanks
Twelvoltz
Platinum - Posts: 2,384
Posted: May 02, 2006 at 7:04 AM / IP Logged
Posting the year of the vehicle would help greatly.
laff001
Posted: May 02, 2006 at 7:07 AM / IP Logged
1992 K-reg
Twelvoltz
Posted: May 02, 2006 at 7:16 AM / IP Logged
1992 BMW 3 Series.
You would just use the information on the page as a reference to make the job easier. Verify all circuits with a DMM prior to making your connections.
Hope this helps.
Keep us posted.
laff001
Posted: May 02, 2006 at 7:28 AM / IP Logged
its mainly the wires coming from the relays for the remote start that i dont know were to put
laff001
Posted: May 02, 2006 at 3:05 PM / IP Logged
Could anyone please tell me, were to connect the starting sensor wire on the 6 cylindor E36 BMW engine please thanks again
laff001
Posted: May 02, 2006 at 4:18 PM / IP Logged
I need to put a wire to the high coil i cant find the high coil on the car 6 cylindor engine BMW E36 1992 329 engine could anyone help on this
Twelvoltz
Posted: May 02, 2006 at 4:32 PM / IP Logged
High coil? Do you mean the tachometer connection? If you check the link that was posted DEI lists the tachometer wire as a black wire with this note "The wire is located in a white connector behind the instrument cluster. Do not unplug the white connector with the ignition on or turn the ignition on with the plug disconnected."
get2me
Posted: May 03, 2006 at 12:14 AM / IP Logged
i'm rookieing my way through an installation now myself. the high coil on my diagram is the fat wire from the distributor that looks like a spark plug wire (i.e. the 7th spark plug wire.)  someone mentioned i could use any one of the spark plug wires also.  but my instructions is to wrap the alarm wire 2 to 5 times around this high coil wire.  not sure if you can use this alarm wire with the tachometer system.
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
