Posted: May 06, 2006 at 9:50 PM / IP Logged
Posted: May 06, 2006 at 10:03 PM / IP Logged
Posted: May 06, 2006 at 10:45 PM / IP Logged
Posted: May 07, 2006 at 12:45 AM / IP Logged
Posted: May 07, 2006 at 1:45 AM / IP Logged
Posted: May 07, 2006 at 12:06 PM / IP Logged
Posted: May 07, 2006 at 1:14 PM / IP Logged
Posted: May 07, 2006 at 1:33 PM / IP Logged
Posted: May 07, 2006 at 2:18 PM / IP Logged
Posted: May 07, 2006 at 2:40 PM / IP Logged
Thursday, February 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
It was a mistake to say I used the wrong wires, I used 4 gauge. There are three amps in this system pushing close to 1000 watts RMS. The largest fuses I had at the time were cheap 50-60 amp AGU, the ones with defective solder.
Also his alternator is weak, idling at about 12.9 volts on average and maxing at 13.4
Since I knew this knuckle head would max his volume I kept the gains down knowing that a dip in voltage would cause the fuses to blow prematurly and potential charging system failure.
So I guess there are such a thing as strappable amps, but my question still is what damage can be done in the above diagram. As far as I can tell there is no benefit in audio output, so doing all that was just a waste of time. But what do I tell this guy that doesn't seem to care about my MECP cert and my years of experience at Best Buy.
I don't want to say its bad "because I said so" In his mind it played louder than what I did, so I don't know what I'm taklking about.
