1995 Toyota 4Runner, Rear Speaker Amp Turn On Wire
punkskt676
Posted: May 08, 2006 at 4:56 PM / IP Logged
i have a 1995 toyota 4runner with a premium factory sound system, witch means it has the factory amp behind the dash that you have to get rid of. i pulled the amp wired up the deck and plugged the harness in.  the problem i am haveing is that there is hardly any sound comeing out of the back speakers now! i read on another post about a 1993 4runner that you had to run a power feed to a certain wire to compinsate for the amp, it was a pink wire with a blue stripe i think, i looked all over in the dash and couldnt mannage to find this wire on the 95. is there an easy way to fix this, or do i have to rewire the truck from the deck to the rear speakers?
tom
mad550
Copper - Posts: 201
Posted: May 08, 2006 at 5:02 PM / IP Logged
The rear speakers have an amp on each one even though they're only 4" the pink wire is the remote wire to turn them on and should be on the main stereo harness next to a BLACK/ red wire which is the auto antenna and the Illumination GREEN/ red
WOW Sight and Sound
Maroochydore
Nothing is impossible!
Do it right the first time or don't do it at all.
punkskt676
Posted: May 08, 2006 at 5:39 PM / IP Logged
soo what your saying is that i should pull this wire out of the harness and wire it into a 12V power source  because right now it doesnt look like its running to anything and the 12v source on the back of the deck is obviously used up allready soo i should get it from some where else.
tom
mad550
Copper - Posts: 201
Posted: May 08, 2006 at 8:03 PM / IP Logged
The pink/blue should go all the way to the back, hook up to remote wire on the deck usually a blue or blue/white
WOW Sight and Sound
Maroochydore
punkskt676
Posted: May 09, 2006 at 12:38 PM / IP Logged
thanks a million hooked it up and it works like magic
tom
mad550
Copper - Posts: 201
Posted: May 10, 2006 at 4:50 PM / IP Logged
No prob man
WOW Sight and Sound
Maroochydore
Sunday, May 5, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
