alarm horn
numbah 001
Posted: May 22, 2006 at 8:15 AM / IP Logged
 hey, 12,  I have an 97 honda prelude, an the door locks kill switch everything is working correctley but eveytime I touch the noise maker to the power sorce it starts blaring. it will still start up and everything just will not stop sounding off.   also I forgot to mention that the inside passenger door handle is broken could that be the reason for my greaving.
will
numbah 001
Posted: May 27, 2006 at 7:45 PM / IP Logged
hey murph, tried what you said and still go's off, I'm thinking i've got to get the door handle replaced first or should that matter?  ( here's what i did : hit the unlock button to disenguage the alarm and locks then put the ley in the ignition turn to the on position but not starting it and connected the power wire and there gos the alarm).
will
Twelvoltz
Platinum - Posts: 2,384
Posted: May 27, 2006 at 8:10 PM / IP Logged
You are installing this system now, or was it an existing install? While the siren is going off, does the alarm's remote still lock and unlock the doors?
