viper 791XV crank but won't start
cantur77
Posted: May 22, 2006 at 11:01 PM / IP Logged
Hey guys, need your help. I installed a viper 791 XV in my 02 F150 and everything works and it will crank but it won't start. Does anyone know why that might be? I used the following diagrams
12V|yellow & lt. grn/pur|+ |ignition harness |
| STARTER|RED / lt. blue |+ |ignition harness |
| IGNITION|dk. blue/lt. green |+ |ignition harness |
| SECOND IGNITION|gray / YELLOW |+ |ignition harness |
| THIRD IGNITION|lt. blue/pink *1 |+ |ignition harness |
| ACCESSORY|RED / black |+ |ignition harness |
| SECOND ACCESSORY|BLACK/ green |+ |ignition harness |
| POWER LOCK|pink / YELLOW |*2 |passenger kick panel |
| POWER UNLOCK|pink/green *8 |*2 |passenger kick panel |
| PARKING LIGHTS +|brown | |light switch *3 |
| PARKING LIGHTS -|lt. GREEN/ YELLOW | |light switch *4 |
| HEADLIGHTS|RED / yellow |+ |light switch |
| DOOR TRIGGER|blk/yel & blk/pnk |- |*5 |
| DOME SUPERVISION|BLACK/ lt.blue |+ |passenger kick panel |
| FCTRY ALARM ARM|*6 | | |
|FCTRY ALRM DISARM|dark GREEN/ purple |- |drivers kick panel |
| TACHOMETER|*7 | | |
| BRAKE WIRE|light green |+ |at switch *3 |
| HORN TRIGGER|dk. blue |- |steering column |
| WIPERS| | | |
| LF WINDOW UP/DN|org/wht - wht/blk |A |in drivers door |
| RF WINDOW UP/DN|wht/yel - tan/lt.blu|A |drivers kick panel |
| LR WINDOW UP/DN| | | |
| RR WINDOW UP/DN| | | |
the other diagram is:
Security
Battery          YELLOW +              (+)           IGNITION SWITCH HARNESS
Ignition         DRK.BLUE/LT.G             (+)           AND BLU/GRN AT IGN SWITCH HARNESS
Starter01 RED / LT.BLUE + (+) IGNITION SWITCH HARNESS
AllDoorTrigger           DRK.GRN/ORNGE         (-)            AT GEM MODULE PIN 9 OF 26 PIN CONN.
FrontLeftDoorTrigger        BLACK / YELLOW            -      AT GEM MODULE PIN 8 OF 26 PIN CONN.
FrontRightDoorTrigger      BLACK/ PINK                   -      AT GEM MODULE PIN 7 OF 26 PIN CONN.
RearLeftDoorTrigger         BLACK/ PINK                   -
RearRightDoorTrigger       BLACK/ PINK                   -      AT GEM MODULE PIN 7 OF 26 PIN CONN.
TrunkTrigger             N/A
HoodTrigger              N/A
FactoryAlarmDisarm         DK.GREEN/ VIOL                   DRIVER'S KICK PANEL
ParkingLights BROWN + (+) AT HEAD LIGHT SWITCH
Remote Start
Ignition02                  GRAY / YELLOW +           (+)           IGNITION SWITCH HARNESS
Ignition03                  RED / BLACK +                        IGNITION SWITCH HARNESS
Accessory01             BLACK/ LT.GREE            (+)           IGNITION SWITCH HARNESS
Accessory02                    +
AntiTheftType            UNDER DASH PAD
AntiTheftSystem        PATS
KeySense                  BLACK/ PINK -                 (-)            STEERING COLUMN HARNESS
NeutralSafety            RED / LT.BLUE +              (+)           IGNITION SWITCH
Tach             LT.GREEN/ WHIT            (-)            AT PCM PIN 26 OF 104 CONN.
CrankShaftSensor             GRAY                      +             PIN 26 OF 104 CONN. AT PCM
CamShaftSensor       DARK GREEN                +             PIN 22 OF 104 CONN. AT PCM
SpeedSense             GRAY/BLACK AC           (AC)        PIN 68 OR 58 AT PCM
BrakeLights               LT.GREEN +                   (+)           AT BRAKE SWITCH
ReverseLights BLACK/ PINK + (+) AT HARNESS TO REAR OR AT SEC. MODULE
Horn DARK/BLUE - STEERING COLUMN
Doorlocks / Window
PowerUnLock            PINK/GREEN                  (-)            DRV KICK PANEL (REV POL ON BASE MODEL)
PowerLock                PINK / YELLOW                (-)            DRV KICK PANEL (REV POL ON BASE MODEL)
DriverDoorMotor01           RED / ORANGE                (+)           DRIVERS DOOR BOOT
DriverDoorMotor02           PINK/BLACK                   (+)           DRIVERS DOOR BOOT
PassengerDoorMotor01    PINK/ORANGE                      KEYLESS MODULE
LeftFrontWindow01           WHITE/ YELLOW             +
LeftFrontWindow02           WHITE/ BLACK                +             AT MASTER SWITCH
Does anyone know why the accesory wire in the first diagram is RED / Black and on the second diagram this wire is the ignition 3. I hooked up my accesory wire to the BLACK/ light Green wire like it said in the second diagram. Also, I believe I tapped into the right tach wire because the LED did lit up when learning the code.
grc
cntrylvr79
Silver - Posts: 582
Posted: May 22, 2006 at 11:21 PM / IP Logged
Did you use a bypass module for the pats system?  Is the theft light in the gauge cluster flashing rapidly when you try remote starting the truck?  If it is then there's something wrong with oyur bypass module.
Cause I'm So white and nerdy...
First Class Certi-fried installer
KarTuneMan
Platinum - Posts: 7,056
Posted: May 23, 2006 at 8:47 AM / IP Logged
put the key IN the ignition cylinder, dont turn it. THEN hit the remote start......what happens then?
Moderator - Posts: 12,488
Posted: May 23, 2006 at 9:53 AM / IP Logged
The RED / BLACK is an ACC wire. Just make sure you attach all the IGN & ACC wires otherwise the Ford's will not crank. As stated above make sure you test to make sure that your bypass module is infact working properly too.
cantur77
Posted: May 25, 2006 at 3:48 PM / IP Logged
Hey guys sorry for not getting back in to the forum as quick as you guys did.  No I did not add a bypass module for the PATS system so I did as you guys told me with the key in the ignition and guess what? It started !  I will buy the bypass moudule but the question is where? do I need to buy a DEI product or can it be another aftermarket module.?  Also, will I have to hook it underneath the steering column? if so, where is the air bag sensor so I don't accidentally trip it.
grc
cntrylvr79
Silver - Posts: 582
Posted: May 25, 2006 at 7:13 PM / IP Logged
You can get pretty much any brand bypass. Just make sure it's for your truck.  As for where to get one.  If you want to get it locally any car audio shop, or best butt I mean buy will have it.  Or you could buy online.  Online will more than likely be cheaper, but you'll have to wait from it.  It does hook up under the steering column.  I wouldn't worry about tripping the airbag, just don't cut into any wires in yellow loom or with yellow tape on them.
cantur77
Posted: May 25, 2006 at 9:23 PM / IP Logged
Thanks a bunch for your help man, you are a life saver.  Thanks also for the tip on BB and the humor with it.  I'll try to get it from there over the weekend and install it right away.  I really hate to have to go out to the driveway in the mornings to start the truck for warm up and having to leave it unlocked and unattended while I finish getting ready.
grc
