missing remote on viper alarm
donvito08
Member - Posts: 43
Posted: May 23, 2006 at 9:12 PM / IP Logged
ok so a buddy of mine traded me a viper 350 hv alarm for installing some stuff for him but he only has one remote the otehr one was "stolen" is there any way to reprogram the unit so that only my one remote will work it?
spookiestylez
Silver - Posts: 531
Posted: May 23, 2006 at 9:59 PM / IP Logged
the one remote should work now, search for programming dei remotes, also all replacment remote will work too and have programming instructions on the package.If I remember correctly.Turn the ignition on then off, press and hold the vprogramming button,after the chirp press then lock button on the remote, then turn the IGN o and off again, siren should chirp. Ill check a extra  install book tomorrow at work at post back if I gave the wrong answer.GL
sS
donvito08
Member - Posts: 43
Posted: May 23, 2006 at 10:03 PM / IP Logged
the remote i have does work what im asking is there any way from keeping the lost remote from working my alarm i dont like the feeling that some random person could disarm my alarm
spookiestylez
Silver - Posts: 531
Posted: May 23, 2006 at 10:44 PM / IP Logged
since the *other* remote is already programmed to that alarm, no...you kinda screwd on that deal unless someone else here knows something I dont.
sS
donvito08
Member - Posts: 43
Posted: May 23, 2006 at 10:46 PM / IP Logged
would addding the 2 way antenna and 2 way remote to this make only the two way remote work on the alarm on this forum iv seen people saying this alarm is 2 way ready
cntrylvr79
Silver - Posts: 582
Posted: May 23, 2006 at 11:11 PM / IP Logged
Actually you can delete the missing transmitter from the system.  Here's what you do. Open the door turn the ignition on.  Push the valet button 9 times.  Then push and hold it.  The siren will chirp and the led will flash 9 times.  While still holding the valet button, push the lock button on the transmitter.  The siren should chirp once.  That will erase all the transmitters from the systems memory.  Now to reprogram the transmitter back to the alarm.  Turn the igniton back on and push the valet button once.  Then push and hold it.  The siren will chirp and the led will flash once.  While still holding the valet button, push the lock button on each transmitter you want to program to the system.  ONce you do that just shut the car up and test it out.  Should work fine for you.
Cause I'm So white and nerdy...
First Class Certi-fried installer
