2000 Mitsubishi Galant remote start
orion_247
Posted: June 01, 2006 at 3:13 PM / IP Logged
Hello, I have 2000 Mitsubishi Galant ES 4 cylinder I got a 564t hornet alarm installed in it just as my other car. I went back to get the remote start added and they gave me an outrageous price. So I bought the bypass module and an extra key but can any help me out with a complete wiring diagram for my car? I would appreciate any and all help I can get, thanks.
orion_247
prdjr165
Copper - Posts: 293
Posted: June 01, 2006 at 3:17 PM / IP Logged
MODEL YEAR(S)
GALANT   1999 -2001
KEY T-HARNESS IMMOBILIZER
N/A    N/A    MITSUBISHI TRANSPONDER ANTI-THEFT SYSTEM, Requires 791 Bypass Module and extra Ignition Key
PART   COLOR LOCATION DIAGRAM
12 VOLT CONSTANT   BLUE / YELLOW (+)    IGNITION SWITCH HARNESS
STARTER BLACK / YELLOW (+)   IGNITION SWITCH HARNESS
STARTER 2 N/A
IGNITION 1 BLACK/ WHITE (+) IGNITION SWITCH HARNESS
IGNITION 2 N/A
IGNITION 3 N/A
ACCESSORY /HEATER BLOWER 1 BLUE/RED (+)   IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER 2 BLUE/BLACK (+)   IGNITION SWITCH HARNESS
KEYSENSE BLUE/RED (-)   IGNITION SWITCH HARNESS
PARKING LIGHTS ( - ) N/A
PARKING LIGHTS ( + ) GREEN / WHITE (+)   @ FUSEBOX
POWER LOCK PURPLE (TYPE B)   IN EITHER KICK PANEL, See NOTE *1
POWER UNLOCK LIGHT GREEN/ RED (TYPE B)   IN EITHER KICK PANEL, See NOTE *1
LOCK MOTOR WIRE BLUE/RED (+)   IN DRIVERS KICK PANEL
DOOR TRIGGER GREEN/ ORANGE (-)   @ TOP FRONT OF THE FUSEBOX
DOMELIGHT SUPERVISION USE DOOR TRIGGER
TRUNK RELEASE N/A
SLIDING POWER DOOR N/A
HORN GREEN / WHITE (+) See NOTE *2   @ HORN RELAY, IN ENGINE COMPARTMENT
TACH WHITE See NOTE *3   @ INSTRUMENT CLUSTER or DISTRIBUTOR
WAIT TO START LIGHT N/A
BRAKE GREEN (+)   @ SWITCH ABOVE BRAKE PEDAL
FACTORY ALARM DISARM   RED (-) See NOTE *4   IN DRIVERS SIDE KICK PANEL
ANTI-THEFT TRANSPONDER ANTI-THEFT SYSTEM, REQUIRES 791 BYPASS MODULE AND EXTRA IGNITION KEY   TRANSPONDER @ IGNITION SWITCH TUMBLER
NOTES
NOTE *1 THESE WIRES ARE IN A BLACK PLUG BEHIND THE FUSEBOX ABOVE GREEN MODULE.
NOTE *2 ALSO FOUND RIGHT AT THE HORN BEHIND LEFT SIDE OF FRONT BUMPER.
orion_247
Posted: June 01, 2006 at 3:18 PM / IP Logged
orion_247 wrote:
Hello, I have 2000 Mitsubishi Galant ES 4 cylinder I got a 564t hornet alarm installed in it just as my other car. I went back to get the remote start added and they gave me an outrageous price. So I bought the bypass module and an extra key but can any help me out with a complete wiring diagram or installation instructions for my specific car? I would appreciate any and all help I can get, thanks.
orion_247
Friday, May 17, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
