2002 Ford Explorer Security
petefisher78
Posted: June 02, 2006 at 2:38 PM / IP Logged
Can anyone provide me with the wiring diagram or information for a 2002 Ford Explorer CENTRAL SECURITY MODULE?  Thanks!
samcouger
Posted: June 28, 2006 at 5:02 AM / IP Logged
12volts yellow  +  ignition harness
Starter red  +  ignition harness
Ignition RED / lt. green  +  ignition harness
Power Lock pink / YELLOW  -  driver kick panel or CSM
Notes: The CSM (Central Security Module) is below the passenger side C pillar.
Power Unlock pink/lt. green  -  driver kick panel or CSM
The GEM in this vehicle shuts down after the doors have been locked for a certain time period, to wake-up the system refer to directfax document #1094.
Lock Motor pink/black    driver kick panel or CSM
Unlock Motor RED / orange    driver kick panel or CSM
Disarm Defeat pink/orange    driver B pillar or CSM
Parking Lights+ brown    headlight sw or driver kick
Parking Lights- N/A
Hazards
Turn Signal(L)
Turn Signal(R)
Door Trigger BLACK/ lt. blue  +  driver kick panel
Dome Supervision use door trigger
Trunk/Hatch Pin common with doors
Hood Pin
Trunk/Hatch Release org/lt. grn or pur/yel  +  Central Security Module
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm GREEN/ purple  -  driver dr harness or CSM
Disarm No Unlock see factory alarm disarm
Tachometer   ac  ignition coil/coil pack
Notes: For tach go to one of the ignition coils or coil pack and use the wire that is NOT WHITE/ lt. blue.
Horn Trigger yellow/lt grn or yellow/lt blu -  steering column or CSM
Memory Seat 1 BROWN / lt. green  +  driver seat mod under seat
Memory Seat 2 BLACK/ orange  +  driver seat mod under seat
Friday, August 29, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
