2006 Chevy HHR, vss lead?
hvrod
Posted: June 05, 2006 at 12:14 PM / IP Logged
I have a 2006 Chevy HHR, need to find where the Speed detection circuit lead to splice into for the Car Speed signal input.
thanks..
djfearny2
Silver - Posts: 810
Posted: June 05, 2006 at 12:41 PM / IP Logged
the vss is located i one of the wheel wells it is a harness that passes though from either inside the engine bay or inside the trunk to the wheel well. through a grommet. it is located to the front side of the coil over springs i believe it is a two wire. harness and the green wire is the vss. i dont believe you can cause error on this wire if you do a trial and error test. but this is the wheel speed sensor and this is where you will get your vss signal.
Jon
Installer/Help Technician
---coral springs florida---
