Best place to tap wires?
justinking06031
Posted: June 08, 2006 at 9:05 PM / IP Logged
I am looking at installing the passive starter kill as shown in the diagrams section. (using the power antenna wire)
My question is this:
what is the best place to tap into each one (ignition 12v, key side starter, motor side starter)?
do the key side and motor side of the starter connections need to actually be run to the starter (relay) -- isnt this somewhat obvious, even if you wire loom them?
Thanks,
Justin
duct tape
Copper - Posts: 125
Posted: June 18, 2006 at 5:28 PM / IP Logged
yes, you need to wire the key side and the starter side to the relay.   usually this is done at the ignition harness, but you could also do this under the hood if you want it to be more stealth.
Wednesday, March 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
