2000 nissan maxima woofer
Cbr629
Copper - Posts: 79
Posted: June 13, 2006 at 5:00 PM / IP Logged
I blew my factory 8' woofer,will any 8' woofer work?
thanks
geepherder
Platinum - Posts: 3,668
Posted: June 13, 2006 at 9:33 PM / IP Logged
If you're just looking to put something in as a replacement and use the factory amp, here's a couple things to consider.  You need to make sure your factory amp will handle the impedence load from the new woofer (how many ohms is it compared to the old one- higher is okay, less is not).  Also, if your woofer is designed to run as the factory one did (in the same size enclosure as the factory woofer, or free-air if it's mounted to the rear deck).
Personally, I'd consider an aftermarket amp/box as well.
aznboi3644
Gold - Posts: 2,600
Posted: June 14, 2006 at 1:08 AM / IP Logged
Go aftermarket...factory amp prolly isnt that powerful.
One 10 and a small amp would some a lot better than that factory stuff.
Monday, May 6, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
