2007 tahoe accessory wire +
stereo1instaler
Posted: June 21, 2006 at 12:51 AM / IP Logged
i'm trying to get positive accessory power but, i checked the ignition harness
and all i found was negative wires that i think they work as signals instead of power
aznboi3644
Gold - Posts: 2,600
Posted: June 21, 2006 at 1:13 AM / IP Logged
Used a DMM right?
geepherder
Platinum - Posts: 3,668
Posted: June 21, 2006 at 9:28 AM / IP Logged
Ctoh
Copper - Posts: 123
Posted: June 21, 2006 at 9:02 PM / IP Logged
Take off the driver kick panel, there will be a connector about 3" wide with about 10-12 wires in it, on the firewall side of the plug you will find a thick purple wire, right next to it will be a dark green wire, this is the wire we use for 12v+ accessory.  The pink wire shown in the guides are supported by a factory 2 amp fuse that if blown will not let the vehicle start so be very careful of this wire,,,,
