1995 toyota carina alarm wiring
kiwiguydan
Posted: June 23, 2006 at 8:22 PM / IP Logged
Hi there,
I am attempting to install a Fusion f-2000 alarm in my 1995 Toyota Carina ED (S limited).
There isn't wiring info for this car in the database. It appears similar to a 95 Celica but i'm not sure how similar. Mainly the relevant wire colours/locations is what I'm after.
Thanks for any help,
Dan.
pmh61
Copper - Posts: 151
Posted: June 24, 2006 at 2:08 AM / IP Logged
THIS IS FOR A 1993 MODEL THIS IS ALL COULD FIND SO DON'T TAKE THIS TO HEART BUT IT IS THE BEST I COULD DO (AND I AM NOT YELLING AT YOU JUST WANT YOU TO READ THIS BEFORE YOU TEAR INTO ANYTHING)
12volts
Starter      BLACK/ white             ignition harness
Second Starter
Ignition      wht/rd or blu/red             ignition harness
Notes: Fuel pump wire is blue/black in the o/s/f sill loom.
Second Ignition
Third Ignition
Accessory      BLACK / YELLOW             ignition harness
Second Accessory      pink/blue             ignition harness
Keysense
Power Lock      brn/wht or blu/red       -       entry point from door to veh
Power Unlock      brn/yel or blu/blk       -       entry point from door to veh
Lock Motor
Unlock Motor
Parking Lights+      grn/blk & grn/yel             under the steering column
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger      RED / white       -       o/s/f kick panel
Dome Supervision
Trunk/Hatch Pin
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer
Wait to start
Brake Wire
Parking Brake
Horn Trigger
Memory Seat 1
Memory Seat 2
Memory Seat 3
kiwiguydan
Posted: June 26, 2006 at 1:35 AM / IP Logged
Thanks for that.
Ive been testing wires with my multimeter and most of them are different in my 95 model. I have most of them identified its just the central locking im working on now. If anyone does find wiring colour info for a 1995 toyota carina ED I'd be keen to see it. I suspect I'll be asking how to diode isolate my door locks soon, im pretty sure they are negative polarity.
Thanks again. Dan.
