Unknown Alarm system
aegis
Posted: June 24, 2006 at 12:36 AM / IP Logged
I have a 1994 Isuzu Trooper that had an alarm with keyless entry which I bought 8 years ago. Unless you press the remote to turn off the alarm the truck will not start. I have lost the only remote I have and now the truck has been sitting in the parking lot for a while because I cannot start it without the remote. Does anyone know where I can look in the vehicle to see what type of alarm is installed. What should I look for? I am sure I can buy a replacement remote but I need to know what alarm is on the truck. I tried pulling out everything under the dash and found nothing other than a little Isuzu box. Even if I can somehow disconnect the ignition from the alarm would be okay with me, I just need to get it to start. Any advice is much appreciated!
swamprat323
Gold - Posts: 1,335
Posted: June 24, 2006 at 5:48 PM / IP Logged
just goihn to look high up under the dash, follow the wires back form the LED, also you shold have a valet swith some were to over the alarm if the batties die in the remote or the remote dies.
iskidoo
Silver - Posts: 1,048
Posted: June 25, 2006 at 3:54 PM / IP Logged
Just try to locate a starter kill relay in the heavy gauge wires going to the key. If you locate it just reconnect the starter wire that was seperated.
Steve G
aegis
Posted: June 30, 2006 at 11:41 PM / IP Logged
Thanks for the help guys, but I figured it out. The box I found earlier that I thought was the computer for the Isuzu was the alarm module. All I had to do was disconnect everything and it started up. I am without an alarm or keyless entry but it runs great. The kicker is that after I did all that, I found the remote, go figure...
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
