'06 Dodge Charger, hardwire Sirius
rudydapimp
Copper - Posts: 390
Posted: June 29, 2006 at 9:17 PM / IP Logged
All right, Using Sirius hardwire kit from Crutchfield.com, ran antenna, put antenna box in behind radio, mounted the satellite radio unit, but am at a loss for the 12 switched. Don't really want to mess with the CAN bus, but is there a wire in the radio haness that is the 12v switched?? would just run a wire from fuse panel, but not really an option, one fuse box in trunk and other under hood. Any help would be greatly appreciate. looked under dash and I did not see any wires easily accessible. Please, need this hooked up!!!
geepherder
Platinum - Posts: 3,668
Posted: June 30, 2006 at 8:15 AM / IP Logged
Check the cigarette lighter, otherwise pink/white at the steering column is ignition.  Test with a meter.
rudydapimp
Copper - Posts: 390
Posted: June 30, 2006 at 8:21 AM / IP Logged
thanks much. will check this out!!
