Rockford Fosgate RFP-1215
lancelot
Member - Posts: 17
Posted: July 01, 2006 at 7:21 PM / IP Logged
I have found one of these subs and I am thinking about purchasing it...however, I have noticed that the (spider, or voice coil, not sure which) circular yellow thingy that surrounds the base of the cone is not flat...it is drawn downwards...I have also noticed (with my trusty DMM) that the impedance on each voice coil is 2.3ohms...
Are these subs garbage now? on their way to being garbage?
Or, is that normal for this sub?
I had also noticed a RFP-1415's yellow thingy, and it was perfectly flat...
lancelot
Member - Posts: 17
Posted: July 01, 2006 at 7:37 PM / IP Logged
I just wanted to edit the post but couldn't figure out how...here's the specs. for the woofer:
Here
It says power handling is 500W RMS...is that per coil?
jvillefinest
Copper - Posts: 255
Posted: July 02, 2006 at 4:54 PM / IP Logged
ehhh i would probably shy away from that one. if im following what your saying, if you look at the sub from the side and right above the magnet. if that is sunk in and isnt ridged enough to hold up the cone of the woffer something isnt to right. if thats what your talking about. also try pushing the sub in and outward if it feels crunchy or doesnt move freely then def dont mess with it
2007 Acura TSX
SQ setup in the works
