Wiring Diagram for 2005 Mitsubishi Galant
seywhut
Posted: July 04, 2006 at 9:21 PM / IP Logged
Does any body have or know where I could find a wiring diagram for a 2005 Mitsubishi Galant on Remote Start, Security, Audio & Accessories?
I tried installing the Arctic Start but have some troubles:
1. I don't know what the "5wi" is,
2. where the ingnition coil/fuel injector wire is for the tachometer,
3. I'm not sure if the ETACS ECU wiring is the one connected to it, how do you know which pin is the right one.
4. Where the parking light is located? Because on the link I used on the bottom, I saw that the parking light & trunk release were the same color.
Note: I don't know if the thread here here is the same one as my model because there were 2004 models which is old and new versions.
Thanks in advance.
xscash
Copper - Posts: 317
Posted: July 05, 2006 at 2:34 PM / IP Logged
here you go
2004 -2005
 KEY  T-HARNESS  IMMOBILIZER
  N/A    N/A    MITSUBISHI TRANSPONDER ANTI-THEFT SYSTEM, Requires 791 Bypass Module and extra Ignition Key
 PART   COLOR  LOCATION  DIAGRAM
 12 VOLT CONSTANT   BLUE / YELLOW (+)    IGNITION SWITCH HARNESS
 STARTER  BLACK / YELLOW (+)   IGNITION SWITCH HARNESS
 STARTER 2  N/A
 IGNITION 1  BLACK/ WHITE (+)  IGNITION SWITCH HARNESS
 IGNITION 2  N/A
 IGNITION 3  N/A
 ACCESSORY /HEATER BLOWER 1  BLUE/RED (+)   IGNITION SWITCH HARNESS
 ACCESSORY /HEATER BLOWER 2  BLUE/BLACK (+)   IGNITION SWITCH HARNESS
 KEYSENSE  N/A
 PARKING LIGHTS ( - )  N/A
 PARKING LIGHTS ( + )  GREEN/ ORANGE (+) and GREEN / WHITE (+) Use BOTH, See NOTE *3   IN DRIVERS KICK PANEL, See DIAGRAM   26500_GALANT_DUAL PARKING LIGHT DIAGRAM.pdf
 POWER LOCK  PURPLE (TYPE B)   @ ETACS ECU, Pin 33, See NOTE *1
 POWER UNLOCK  LIGHT GREEN/ RED (TYPE B)   @ ETACS ECU, Pin 34, See NOTE *1
 LOCK MOTOR WIRE  BLUE/RED (+)   @ 28-PIN PLUG, PIN 19, BELOW FUSEBOX
 DOOR TRIGGER  See NOTE *2      14301_GALANT_(-) NEGATIVE DOOR PIN ISOLATION CIRCUIT.pdf
 DOMELIGHT SUPERVISION  RED / GREEN (-)   @ PIN 1, IN 3-PIN PLUG, ABOVE FUSES
 TRUNK RELEASE  GREEN / WHITE (5 WIRE) See NOTE *4   @ ETACS ECU, PIN 32, See NOTE *1   14301_GALANT_5-WIRE TRUNK RELEASE DIAGRAM.pdf
 SLIDING POWER DOOR  N/A
 HORN  LIGHT GREEN (-)   IN PIN 44, @ ETACS ECU, OR AT STEERING COLUMN
 TACH  Any wire NOT BLACK/ WHITE or BLACK   @ ANY IGNITION COIL
 WAIT TO START LIGHT  N/A
 BRAKE  GREEN (+)   @ SWITCH ABOVE BRAKE PEDAL
 FACTORY ALARM DISARM   RED / GREEN (-)   @ ETACS ECU, PIN 25, See NOTE *1
 ANTI-THEFT  TRANSPONDER ANTI-THEFT SYSTEM, REQUIRES 791 BYPASS MODULE AND EXTRA IGNITION KEY   TRANSPONDER @ IGNITION SWITCH TUMBLER
NOTES
 NOTE *1 ETACS (Electronic Timing/Alarm Control System) ECU (Electronic Control Unit) IS ATTACHED TO THE BACK OF THE FUSEBOX.
NOTE *2 THE LEFT FRONT AND LEFT REAR DOOR TRIGGERS ARE IN A 15 PIN PLUG ABOVE THE FUSES. THE LEFT FRONT DOOR IS LIGHT GREEN(-) IN PIN 6, AND THE LEFT REAR DOOR IS ORANGE / BLACK(-) IN PIN 10. THE RIGHT FRONT AND RIGHT REAR DOOR TRIGGERS ARE AT THE ETACS ECU. THE RIGHT FRONT DOOR IS YELLOW(-) IN PIN 65, AND THE RIGHT REAR DOOR IS ORANGE / BLACK(-) IN PIN 35. WHEN CONNECTING TO AN ALARM SYSTEM, USE ALL 4 DOOR TRIGGER WIRES AND DIODE ISOLATE, TO CONNECT, SEE DIAGRAM
NOTE *3 THIS VEHICLE HAS 2 PARKING LIGHT WIRES AND WILL REQUIRE BOTH AND 2 EXTRA RELAYS PART #775 TO CONECT THE CIRCUIT, See DIAGRAM
NOTE *4 THIS VEHICLE USES A 5-WIRE TRUNK RELEASE OUTPUT THAT WILL REQUIRE AN EXTRA RELAY PART #775, TO CONNECT, See DIAGRAM
       XS
expandable sound
south of boston
Monday, May 6, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
