Distribution blocks to ground to battery?
tkur
Member - Posts: 27
Posted: July 06, 2006 at 1:17 PM / IP Logged
I have a nagging whine in my system that is very low but I can hear it.  I've checked and rechecked all the grounds and they all OHM out.  What if I wanted to take a distrubution block and runn it directly from the battery into the interior of the vehicle and ground everything to it?  Would it work without causing more problems?  Any suggestions?
Thanks much
Flakman
Copper - Posts: 365
Posted: July 11, 2006 at 4:14 PM / IP Logged
Running ground back to your battery (when only running one battery) is never the best idea. I would agree with nouse and check where your RCAs are running in relation to your power. Always keep grounds as short as possible and make sure it's solid and clean. I would only run back to the battery if using a second batter close to the amps that is strictly for your system.
LOL on the sig nouse.
The Flakman
I feel strange. I have deja vu and amnesia at the same time.
John | Manteca, CA
aznboi3644
Gold - Posts: 2,600
Posted: July 11, 2006 at 4:48 PM / IP Logged
Also a distribution block would just make the resistance higher...crappy brass block coated in crappy nickel plating.
forbidden
Platinum - Posts: 5,354
Posted: July 11, 2006 at 5:00 PM / IP Logged
flakman, please read the what is a proper ground sticky. It might change your views on grounding. Azn invasion, brass is a good conductor of electricity, this is why it is used. The plating on it is for corrosion resistance and wow factor.
aznboi3644
Gold - Posts: 2,600
Posted: July 11, 2006 at 6:47 PM / IP Logged
Eh...yeah...bling bling is cool...Personally I just wouldnt use a dist. block for grounding...I like the for sure wire to sheet metal.
Flakman
Copper - Posts: 365
Posted: July 11, 2006 at 7:17 PM / IP Logged
Agreed forbidden.
The Flakman
John | Manteca, CA
stevdart
Platinum - Posts: 5,816
Posted: July 11, 2006 at 7:45 PM / IP Logged
forbidden wrote:
Azn invasion...
LOL u r such a smartass...but a smart smartass.
haemphyst
Platinum - Posts: 5,059
Posted: July 11, 2006 at 10:30 PM / IP Logged
If I may chime in here... I personally PREFER using a high quality non-fused distribution block for grounding... WAY easier to ground one wire and get it good, than it is to ground 3 or 4 smaller wires... 4 TIMES the chances of getting it wrong!
there... I said it.
auex
Platinum - Posts: 5,041
Posted: July 11, 2006 at 10:57 PM / IP Logged
I agree with this 100%. Much easier to ground 1 large wire then 4 smaller wires.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
aznboi3644
Gold - Posts: 2,600
Posted: July 12, 2006 at 2:12 AM / IP Logged
stevdart wrote:
forbidden wrote:
Azn invasion...
Thanks steve...I'm naturally a smartass to everyone...I even p!ss off my girlfriend every now and then cuz of it lol...not intentionally but its just part of my nature.
peace out,
Azn Invasion
Thursday, February 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
