1997 chevy c/k pickup truck ext cab 3 door
grouse hunter
Posted: January 11, 2003 at 2:34 PM / IP Logged
I was wondering if anyone knows about the door lock switch is it a 3 wire pos or 5 wire reverse polarity? I am adding a keyless entry to the truck and cannot figure it out.
auex
Platinum - Posts: 5,041
Posted: January 11, 2003 at 4:49 PM / IP Logged
Depends on wether or not the truck had keyless entry from the factory.  If it did then it will be 3 wire pos trigger if not then it will be 5 wire reverse polarity.  Lock should be lt.blue and unlock should be white in the drivers kick panel (or at the fuse box?).
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
grouse hunter
Posted: January 11, 2003 at 5:09 PM / IP Logged
The truck did not have keyless entry from factory,so it must be 5 wire reverse. Thanks.
Also I really dont understand the 5 rev polarity system. From what I am looking at the difference between the 3-pos. and the 5 rev. is that you have to connect the master switch to terminal 87a and the door lock actuators to the #30 terminal on the relay my question is why? I put a continuity tester on terminal 30 and 87a and i am getting continuity. Why can't I just tap into #30 terminal?
