Do most people use an amp for thier mids?
nothingface9
Member - Posts: 15
Posted: July 09, 2006 at 3:31 AM / IP Logged
or just for the subwoofers?
12vdeej
Member - Posts: 26
Posted: July 09, 2006 at 6:07 AM / IP Logged
It really depends how much power your mids need. I only have an amp running my sub and let the head unit run the stock mids in the doors as they're loud enough for what I want. If you're trying to run 6 x 9's or sumthing similarly power hungry your head unit will struggle to give them a clean, powerful signal and you will need an additional amp or a powerful multi channel amp.
haemphyst
Platinum - Posts: 5,059
Posted: July 09, 2006 at 9:26 AM / IP Logged
I have dedicated amps for my single 12" sub (2kW+), my mid-bass (370 wpc), my mids (120 wpc), AND my tweeters (85 wpc).
Granted, I am fanatical, and generally speaking, overkill is a good place to start for me, but sure, there's no reason in the world (other than complexity, expense, damage dealing capability, charging system requirements... etc., etc. Do most people use an amp for thier mids? -- posted image. ) to not bi- or tri- amp your system (or, in my case quad-amp).
Pretty much any amplifier will provide a MUCH cleaner output signal to a speaker system than would any head unit. There are a few exceptions to this rule, (both ways) but very few.
kfr01
Gold - Posts: 2,121
Posted: July 09, 2006 at 10:21 PM / IP Logged
While you don't need to get as extreme as haemphyst, I would never run aftermarket mid/high speakers without amping them. :-)
Bi-amping is sufficient for most folks. ;-)
New Project: 2003 Pathfinder
