voltage problems dropping 10’s 9’s even 8
ralphpylayanum1
Member - Posts: 12
Posted: July 19, 2006 at 12:51 AM / IP Logged
i wanna know what is  the big 3 and the big 4, also ive heard about the xstatic batcap mega cap 150 which is 50 farads and 16 volts i heard its very good has 150 amps for to seconds it is rated at 15 volts as fast as a cap and cycle of life unending. any ways i have a massive 3000.1 a ppi pc2600 and a ppi pc4400 im having very bad voltage problems so anything i mean anything that can help me can u guys post it please i also wanna know hot two check for bad things like bad ground and so fourth i have 0 guage from battery two enging plus stock the i have a 150 amp high output alternator with 4 guage to the batery and + stock yellow top battery and a 2.5 farad cap in the back thanks guys
rafael rodriguez
aznboi3644
Gold - Posts: 2,600
Posted: July 19, 2006 at 2:18 AM / IP Logged
Read the big three sticky up above in this forum.
Take that cap out and get a new HUGE high output alternator...I mean massive of your potentially running around 3000 watts its gonna pull some major amps.
Thats well over 400 amps...just a rough estimate...I know it could be more or less.
jeffchilcott
Platinum - Posts: 2,483
Posted: July 19, 2006 at 7:07 AM / IP Logged
you cannot run a 16 volt battery in line with a 12 volt system, your looking to smoke something.   Look into a higher amp alternator from a reputable company.
Irragi, ohio gen, powermaster are all good places to start looking at over a 200 amp alternator
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
androtab
Posted: July 23, 2006 at 11:55 PM / IP Logged
also keep in mind that your cap should be 1 farad for every 500 watts of power.this is additional of course to your h/o alternator..
Sunday, February 8, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
