OEM cruise control, 2001 Malibu
bndr
Posted: July 19, 2006 at 3:16 AM / IP Logged
Hi everybody
I have a 2001 Malibu V6 and I want to install OEM cruise control by swapping the steering wheel.
What other parts should I look for in the junkyard? and what is the installation procedure?
Should I change the ECM or BCM?
I saw an old topic about a drive-by-wire system which makes installing the cruise control easier, does the Malibu have this system?
Any help about would be greatly appreciated, since I am not an expert in these issues and I will let a specialist do it.
sparkie
Platinum - Posts: 2,061
Posted: August 02, 2006 at 4:11 PM / IP Logged
You would require the steering wheel, switches, a new air-bag coil, the cruise main unit with it's throttle cable and both a dash harness and engine harness to get the wires and connectors to make it all work. Do yourself a favour and forget that idea. Buy a Rostra cruise control and use one of their steering wheel mounted cruise controls swithes. They work, give a warranty and won't cause any grief to install.
sparky
Saturday, June 21, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
