04 H2 Auto Headlights Blinking
tjetzer
Member - Posts: 6
Posted: July 21, 2006 at 10:31 AM / IP Logged
I just finished installing a a Clifford RS1.1 into an '04 Hummer H2.  Everything is working fine, however the vehicle owner doesn't like the headlights blinking at night when remote started.  I did try pressing the parking brake to turn them off when remote started but this didn't seem to turn them off.  Any suggestions?
If I can turn them off with the parking brake, where and what wire should I look for, and what polarity does it have?
KarTuneMan
Platinum - Posts: 7,056
Posted: July 21, 2006 at 10:50 AM / IP Logged
Sounds to me like you have the WRONG wire for parking lights. Gray/black @ the switch NEG(-) or brown POS(+) in the drivers kick.
There is also a green NEG(-) trigger @ the headlight switch that will turn OFF the auto headlights,
tjetzer
Member - Posts: 6
Posted: July 21, 2006 at 11:08 AM / IP Logged
Thank you for the reply.  I connected the parking light wire to PARKLIGHTS NEGATIVE gray/black - brown plug, pin b2 at bcm.
So I could either get the parking light wire in the DKP or connect the Green Neg trigger to the ned when remote start wire, right?
KarTuneMan
Posted: July 21, 2006 at 11:33 AM / IP Logged
Well, if you can select the polarity of the parking light flash.....switch to POS(+) and try to find the brown in the kick.  ALL of the info I have showns NEG(-) at the switch...NOT the BCM.
Parking Lights+ brown (L), BROWN / white (R)  +  driver kick, harness to rear
tjetzer
Member - Posts: 6
Posted: July 21, 2006 at 11:39 AM / IP Logged
I will change wires to the kick.  I assume this will stop the headlights from coming on and blinking at night?
Chris Luongo
Platinum - Posts: 3,746
Posted: July 21, 2006 at 4:46 PM / IP Logged
It's because of the DEI remote starter that continually flashes the parking lights on and off.
Program the unit for steady parking lights, and all will be well.
