2007 F350, alarm, remote start
fresh155
Member - Posts: 12
Posted: July 24, 2006 at 11:55 PM / IP Logged
Hello i was hoping if someone can help me out and provide the wiring diagram for a 2007 f350 to install a remote start alarm and window modules for all four windows it is for a diesel and i know i need a timer for the wait to start also if anybody knows if i need an immobilizer bypass it would be helpful as the key looks to small to have the chip thanks to all for your help 2007 F350, alarm, remote start -- posted image.
josh1979
Silver - Posts: 320
Posted: July 26, 2006 at 7:00 PM / IP Logged
i do not have a 07 but heres the 06 not sure if any thig is different.
12voltsyellow (30A), lt grn/pur (30A) + ignition harness
Starterdk. green + ignition harness
Second StarterN/A
IgnitionRED / lt. green + ignition harness
Second IgnitionN/A
Third IgnitionN/A
Accessorygray / YELLOW and RED / black + ignition harness
Second Accessorydk. blue/lt. green + ignition harness
KeysenseBLACK/ pink - ignition harness
Power Lockpink / YELLOW (w/o keyless) 5widriver kick, door harness
Notes: Vehicles with keyless entry, the lock wire is WHITE/ red (-), in the driver kick, door harness or also at the VSM, gray plug, pin 3.
The VSM (Vehicle Security Module) is to the right of the accelerator pedal above the transmission hump below the radio. Not accessible from radio opening.
Power Unlockpink/lt. green (w/o keyless) 5widriver kick, door harness
Notes: Vehicles with keyless entry, the unlock wire is BLACK/ white (-), in the driver kick, door harness or also at the VSM, gray plug, pin 2.
Vehicles with keyless entry the VSM shuts down after the doors have been locked for a certain time period, to wake up the system refer to DirectFax document 1094.
Lock Motorpink/black 5widriver kick or VSM, gray plug, pin 1
Notes: The VSM (Vehicle Security Module) is to the right of the accelerator pedal above the transmission hump below the radio. Not accessible from radio opening.
Unlock MotorRED / orange 5widriver kick or VSM, gray plug, pin 7
Parking Lights+brown + switch or VSM, green plug, pin 2
Parking Lights-N/A
Hazardssame as turn signal wires
Turn Signal(L)lt grn/wht (F), lt grn/org (R) + turn signal switch
Turn Signal(R)wht/lt blu (F), org/lt blu (R) + turn signal switch
Reverse LightBLACK/ pink + back of fuse box, black 8 pin plug
Door Triggeruse dome supervision wire
Notes: The individual door trigger wires rest at ground and go to open circuit when the doors are opened.
On vehicles without keyless entry, the wires are in each kick or at the instrument cluster, blue plug. The driver door is lt. GREEN/ YELLOW in pin 24. The passenger door(s) is pink/lt. blue in pin 23.
On vehicles with keyless entry, the wires are in each kick or at the VSM, gray plug. The LF door is yellow/black in pin 4. The RF door is gray/red in pin 5. The LR door is lt. GREEN/ YELLOW in pin 11. The RR door is pink/lt. blue in pin 6.
Dome SupervisionBLACK/ lt. blue + pass kick or cluster, blu plg, pin26
Trunk/Hatch PinN/A
Hood PinN/A
Trunk/Hatch ReleaseN/A
Power Sliding DoorN/A
Factory Alarm ArmN/A
Factory Alarm DisarmN/A
Disarm No UnlockN/A
TachometerNOT RED / lt green or RED / yellow ac any ignition coil or fuel injector
Notes: On diesel vehicles the tach wire is lt. GREEN / WHITE in a 5 wire harness held up with white tape behind the parking brake release. Can also use the 454T tach signal generator.
Wait to startsee DirectFax document 1091
Notes: On the remote start, make sure to program the Accessory State During Wait To Start to ON.
Brake Wirelt. green + brake pedal switch
Parking Brakelt. GREEN/ red - switch or cluster, blue plug, pin 18
Horn Triggerdk. blue - switch or VSM, green plug, pin 6
Memory Seat 1N/A
Memory Seat 2N/A
Memory Seat 3N/A
Interface Module:Category:
Immobilizer Bypass
Required:
No
Type:
N/A
Part #: N/A
Notes:
Smart Starter Kill Relays:Relay Type:
Starter Relay
Underdash access panel, Driver side #307
Part #: 6401A
Alternate Notes: 6411A, Fuel Pump Relay #302, Underdash access panel, Driver side
Parking Lights-N/A
HeadlightRED / yellow + switch or VSM, green plug, pin 7
Speed Sensegray/black radio harness or ABS module, pin 21
Notes: The ABS module is in the driver side rear corner of the engine compartment.
Wipersdk. blue/orange - windshield wiper switch
LF Window up/dnWHITE/ black - tan/lt. blue A driver window switch in door
RF Window up/dntan/lt. blue - WHITE/ yellow A driver kick, door harness
LR Window up/dnyellow/lt. blue - gray/orange A driver kick, door harness
RR Window up/dnRED / black - yellow/black A driver kick, door harness
Sun Roof open/closepurple - dk. blue A sunroof motor or module
Sun Roof Limit/closewhite, black, or red - sunroof motor or module
Memory Seat 1N/A
Memory Seat 2N/A
Memory Seat 3N/A
bring back the rotary phone so i dont have to press 1 to proceed in english
fresh155
Member - Posts: 12
Posted: July 27, 2006 at 11:40 PM / IP Logged
hey thank you very much i appreciate the help just one quick question my alarm only has one accesory wire do i put all three wire labeled accesory in this diagram into the alarm thanks for the help again
extreme1
Silver - Posts: 1,070
Posted: July 29, 2006 at 12:09 AM / IP Logged
what kind of remote starter?
some have a 2nd ign wire that can beprogrammed or a jumper changed to make it 2nd acc.
if you don't hook up the blue/green wire you get a TBC failure message, this is for the Trailer Brake Controller.
Doesn't damage anything, just annoyuing
Shaughn Murley
Visions Electronics
Red Deer, Alberta
fresh155
Member - Posts: 12
Posted: July 29, 2006 at 10:59 PM / IP Logged
hey thanks extreme1 i revisited the alarm instruction and i saw that if the second iginition is not used in which this case it is not i can use it as an accesory so i will just do that thanks again for the help and by the way the alarm is a hornett 564t
