amp cool down
chucknorris916
Posted: July 25, 2006 at 7:47 AM / IP Logged
my am is located in my trunk and keeps over heating. will mounting cpu fans on the underside of the amp help keep it from over heating or at least prolong it. i already moved the amp off of the fool and it now hovers to try and promote air movement. if not the fans what is a good way to keep the amp cooler
chucknorris916
Posted: July 25, 2006 at 7:48 AM / IP Logged
i ment floor not fool sorry
jeffchilcott
Platinum - Posts: 2,483
Posted: July 25, 2006 at 7:49 AM / IP Logged
What type of amp and what ohm load do you have on it.
Most of the time if the amp is surrounded by nothing there should not be a problem.
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
coppellstereo
Silver - Posts: 785
Posted: July 25, 2006 at 8:29 AM / IP Logged
Lets try and find the reason for overheating 1st.
How quickly does it overheat?
How hard are you driving the amp while listening?
How is your gain set?
Are you sure you have a good ground?
