2003 VW Door Module
Bmlime
Member - Posts: 23
Posted: January 13, 2003 at 4:13 PM / IP Logged
I have a question I recently had a viper 550 esp installed it has problems.The drivers door lock no longer locks with factory remote or button in the ca.But the actuator unlocks. all the other doors are fine.Did my installer blow the door module.
bmlime
AlarmTech
Copper - Posts: 101
Posted: January 15, 2003 at 12:30 PM / IP Logged
i know in our 02 Jetta i found 2 wires that locked the doors, one was rather intermittent with a 200ma pulse but the other worked fine, but i don't recal the colors. " i think" the one i used was Yellow/Blue. But my OEM remote always worked....
did the installer use T-Taps or solder? If T-Taps maybe the wire has been cut by the tap, if soldered, possibly a cold solder joint or even broken....
Viper Equipped
Bmlime
Member - Posts: 23
Posted: January 20, 2003 at 10:46 AM / IP Logged
  Ok my installer messed up something pertaining to the the lock actuator. I have a question this is the scenario.I arm my Viper Alarm I wait ten seconds I go to unlock the door with the remote and the alarm disarms but the doors don't unlock.OK ...Next I remote start my vehicle system is armed I go to unlock my doors and it unlocks fine. Is this what you experienced in your 2002 Jetta..It seems like the factory alarm sleeps the locks to save energy and unable to unlock with the viper remote,the factory remote unlocks them fine. My installer mentioned a Pulse ,But he is unaware how to do it until the wiring diagram comes out for the 2003. Do you have any suggestions??Thanks Bruce
bmlime
jrilla
Gold - Posts: 1,498
Posted: January 20, 2003 at 11:02 AM / IP Logged
Tell the dealer to get it right or give you a full refund and go somewhere else.  That is terrible that you would have to deal with that.
J Rilla
Owner/Installer
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
