compustar 2wfmas into 95 auto taurus sho
tominos
Posted: July 28, 2006 at 8:46 PM / IP Logged
i have a lot of questions, once i get started on this install that i hope you guys here can help me with. i have a wiring diagram for my car, and wiring instructions for the cm3000 that i found on here.
first off, i was looking in the ignition wire harness, and for my compustar it says hook the red 12v constant up to the 12 v constant(which according to the wiring diagram is a yellow wire on the harness). my question is, there is 6 yellow wires in the harness, all exactly the same, how do i know which one to hook up to w/o a multimeter? or does it matter?
second, the parking light (+), the diagram says its a brown wire on the headlight switch harness, i couldn't find a brown wire though. where to look? thanks alot guys.
glantern83
Member - Posts: 32
Posted: July 30, 2006 at 8:51 PM / IP Logged
Go get a decent DMM before you do an install... you have to testeach wre to make sure its what the diagram says its always up to the installer....
-KITT
tominos
Posted: July 31, 2006 at 1:43 AM / IP Logged
its all hooked up and working except for the trunk trigger and trunk release.
for the trunk release, it says to tap the purple / YELLOW (+) from behind the dash, but the compustar sends a 200ma(-) pulse for the trunk release. how do i hook this up? w/ relays?
bbtaco
Copper - Posts: 119
Posted: July 31, 2006 at 7:01 AM / IP Logged
Here is a diagram for 12vdc + trunk release relay wiring.
Trunk release
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
