2006 Honda Civic, power, ground?
ijog
Posted: July 30, 2006 at 2:55 PM / IP Logged
Hello, I have been trying to locate a place that will tell me the correct wiring color code to wire two wires for power. One need to go to the +12 that will only be hot when the ignition is on. The other is negative. The car is a 2006 Honda Civic 4 door. Anyone know where I can connect to these tow wires/connections under the dash on the driver's side. I see a lot of color coded wires under there, but I don't know hwich two wires I need. Are any black wires 12v+ and white negative?
Thanks in anticipation.
John.
KarTuneMan
Platinum - Posts: 7,056
Posted: July 30, 2006 at 5:52 PM / IP Logged
12V constant is white, and Ign. is blue. They are in the same green connector on the front top of the fuse box.
ijog
Posted: July 30, 2006 at 7:56 PM / IP Logged
Thanks for that reply..appreciated. Since I don't want my XM radio to stay on all the time or be charging off the battery, Can you tell me the 12v+ that is on only when the key is on?
Thanks.
Wednesday, November 26, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
