passive crossover
imokureok4
Member - Posts: 8
Posted: August 08, 2006 at 8:42 PM / IP Logged
I just bought a kicker kx450.2 amp and it says that i can run 2 speakers in stereo and at the same time bridge another speaker but it says you need high pass crosovers on the 2 speakers for it 2 work now arent there alot of different kind waht would be an example of what 2 buy??? and where could i get it??
Flakman
Copper - Posts: 365
Posted: August 08, 2006 at 10:43 PM / IP Logged
You can check this out here. https://www.the12volt.com/caraudio/cross.asp#hp
selectproducts.com also has crossovers at http://68.208.124.66/dealer/items.asp?Cartid={A3A602A6-EVERESTED13-4700-B9EB-FB55B71249E9}&Cc=XO%2DPARTS&Bc=
The Flakman
I feel strange. I have deja vu and amnesia at the same time.
John | Manteca, CA
DYohn
Moderator - Posts: 10,741
Posted: August 08, 2006 at 11:31 PM / IP Logged
What you are describing is called "tri-mode."  If your amp is tri-mode capable, you will need to either build or purchase a tri-mode crossover.  This is a high-pass passive for the mains and a low-pass passive for the woofer, set to the same frequency.
Thursday, May 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
